Results 1 to 7 of 7
Thread: Quick selection
    Forum Newbie
    AutoCAD 2016
    Apr 2016
    1
    Default Quick selection
    Hello all, real newbie here..
    My first question is: AutoCad 2016 (student ver.) is there a possible way of selecting one line (property RED) and then have a command that could select all the lines in model space that have the color RED??
    Could it be done with using any of: linetype/lineweight/line color
    ***IF WHILE IN MODEL SPACE EVERYTHING IS ONLY "LAYER 0"***....meaning I didnt use the layer properties
    what if the RED lines are a block? Can I SELECT one block and then USING a SELECTION TOOL it could select all the blocks??
    NOW 18:53- I WILL BE HERE UNTIL TOMORROW NO LATER THEN 09:00 PLEASE HELP ME
    AutoCAD 2013
    Nov 2011
    5,992
    Welcome to CADTutor.
    The command you want is SELECTSIMILAR.
    Follow the commandline prompts.
    You will need to use the SEttings option to define the object types which you are looking for.
    If you were trying to select specific blocks you would want to use the NAME option.
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    11,947
    SELECTSIMILAR or QSELECT should work, you may also want to look into filters for future work.
    Full Member benhubel's Avatar
    benhubel's Computer Details
    Windows 7
    Manufacture
    benhubel's Discipline Details
    Waterjet Programmer
    Manufacture
    AutoCAD 2012
    Dec 2015
    Dallas, Texas
    88
    There is a similar post that was made a while back in the AutoLISP section. Because we are currently in the Beginners' Area, I will assume that you aren't familiar with LISP. Simply follow the instructions below:
    Begin by following this brief tutorial to load the code http://www.lee-mac.com/runlisp.html.
    After loading it, type SelectByColour to start the code, then click on an object of the color you want.
    Code:
    ;Code posted by Lee Mac to http://www.cadtutor.net/forum/showth...color-property.
    (defun c:SelectByColour ( / c d e l )
        (if (setq e (car (entsel)))
                (setq c
                    (cond
                        (   (cdr (assoc 62 (entget e)))   )
                        (   (abs (cdr (assoc 62 (tblsearch "LAYER" (cdr (assoc 8 (entget e)))))))   )
                (while (setq d (tblnext "LAYER" (null d)))
                    (if (= c (abs (cdr (assoc 62 d))))
                        (setq l (cons "," (cons (cdr (assoc 2 d)) l)))
                (sssetfirst nil
                    (ssget "_X"
                        (if l
                            (list
                                (cons -4 "<OR")
                                    (cons 62 c)
                                    (cons -4 "<AND")
                                        (cons 62 256)
                                        (cons 8 (apply 'strcat (cdr l)))
                                    (cons -4 "AND>")
                                (cons -4 "OR>")
                            (list (cons 62 c))
    If you have any problems, let me know, or you can try to summon the almighty Lee Mac by mentioning his name somewhere in your reply. I think it's some sort of dark ritual that conjures him to the mortal plane .
    **Edit**
    When clicking to choose a color, you can select a block, however be aware that it will select by the color assigned to the block even if there aren't any objects of that color within the block. It will ignore the colors within.
    I just now discovered for the first time that I am prone to memory loss.
  5. #5
    AutoCAD 2013
    Nov 2011
    5,992
    Quote Originally Posted by SLW210 View Post
    I always forget about QSELECT, as I have never really needed it, nor integrated it into my work flow, and it is so much more user friendly than the old FILTER command.
  6. #6
    Senior Member Arizona's Avatar
    Arizona's Computer Details
    XP Prp
    Dell Precision 370
    2 Gig
    NVIDIA GeForce 7800 GTX
    2 17" Dells
    Land Desktop 2006
    Dec 2002
    South Jersey, USA
    187
    Quote Originally Posted by Dadgad View Post
    Filter has it's uses. If you have more than one criteria you want to base your selection on, filter works great, although the learning curve on Filter is a little steep. Once I figured out How to work it properly, it's wonderful.
    QSelect seems to only be able to select based on One criteria.
  7. #7
    Forum Deity rkent's Avatar
    rkent's Computer Details
    WIN7 PRO 64bit
    Dell OptiPlex 7020
    i7 4790 3.6GHz
    16GB, 1600MHz, DDR3 non-ECC 2x8GB
    AMD Radeon 2GB
    Samsung 480Gb SSD
    Dell 24" FS (2x)
    Mechanical
    rkent's Discipline Details
    Mechanical
    Mechanical 2017
    Nov 2007
    4,588
    Quote Originally Posted by Arizona View Post
    Qselect can be used for more than one criteria by first going through to select one type of object, hit enter to start it back up, pick the box at the lower left for append to previous, pick another type of object, and go from there.
    I use it when I need Text and Mtext, as a common example.
    Filter is more powerful, no question.
    Sometimes there's a man... I won't say a hero, 'cause, what's a hero? But sometimes, there's a man. And I'm talkin' about the Dude here. Sometimes, there's a man, well, he's the man for his time and place. He fits right in there. And that's the Dude, in Los Angeles. - The Stranger, The Big Lebowski
  1. New Thread Suggestion: Quick Question, Quick Answer
    By Pintoleite in forum Feedback
    Last Post: 11th Apr 2012, 01:23 pm
  2. Quick Selection Lisp
    By nicolas in forum AutoLISP, Visual LISP & DCL
    Last Post: 5th Jun 2011, 07:35 am
  3. Replies: 1
    Last Post: 18th Nov 2010, 01:56 pm
  4. Quick Select/Quick Filter
    By mike06 in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 29th Mar 2008, 01:33 am
  5. quick selection tool
    By marisa in forum AutoCAD Drawing Management & Output
    Last Post: 20th Jul 2006, 02:47 pm
Tags for this Thread
