MrButtonmush Posted April 28, 2016 Share Posted April 28, 2016 Hi Guys, got a question regarding the application of multiple attributes in a block. In space planning I make a lot of blocks with a text code in them that I apply a rotation to so it can be rotated on plan to always be the right way up. i.e. a simple hatched rectangle representing a desk with the word "desk" in it. I would populate a plan but some will be vertical, some diagonal and some horizontal so the rotation allows me to set all the text the way I want it. Now I have also started to apply an array on a linear attribute so I can run a string of desks. Unfortunately, applying this to a block as detailed above allows me to run a string of desks that all have the text in but they all rotate around the initial blocks text rotation point. Can the two features be applied so once the array is run, the text in each block can be rotated individually? Sorry if not clear lol! Quote Link to comment Share on other sites More sharing options...
RobDraw Posted April 28, 2016 Share Posted April 28, 2016 Can you explode the array after placement? Quote Link to comment Share on other sites More sharing options...
steven-g Posted April 28, 2016 Share Posted April 28, 2016 Have you tried making the rotation first and then the array, I tried a sample and that works, even adjusting the array after the rotate causes the text to realign indiviually, but this could be due to a difference in how your block is constructed. If you can post a copy of the block it would be easier to answer (though it may not be possible!) Quote Link to comment Share on other sites More sharing options...
TheCADnoob Posted April 28, 2016 Share Posted April 28, 2016 Try not making the array associative. When you first create the array look in the command line prompt and of of the options is associative. change that option to no and see if it helps. Quote Link to comment Share on other sites More sharing options...
TheCADnoob Posted April 28, 2016 Share Posted April 28, 2016 there is also _ARRAYCLASIC which tastes better than Coke® Quote Link to comment Share on other sites More sharing options...
Ski_Me Posted April 29, 2016 Share Posted April 29, 2016 I have blocks that have text I rotate. I did an array just like steven-g and they all still work after I explode the array. Just make sure you don't lock your text in the attribute definition. Then you will be able to move the text to where you need it. Quote Link to comment Share on other sites More sharing options...
MrButtonmush Posted April 29, 2016 Author Share Posted April 29, 2016 Have you tried making the rotation first and then the array, I tried a sample and that works, even adjusting the array after the rotate causes the text to realign indiviually, but this could be due to a difference in how your block is constructed. If you can post a copy of the block it would be easier to answer (though it may not be possible!) I did do it that way around yes. Block attached. Drawing2.dwg Quote Link to comment Share on other sites More sharing options...
MrButtonmush Posted April 29, 2016 Author Share Posted April 29, 2016 PS. Some of the latter replies seem to imply using a block that only has the rotation value and then using an array on the block. That is not what I am asking about if that is what you mean. Quote Link to comment Share on other sites More sharing options...
RobDraw Posted April 29, 2016 Share Posted April 29, 2016 If there is confusion, you should restate the question in a different way and illustrate what you mean so that they will understand. Quote Link to comment Share on other sites More sharing options...
MrButtonmush Posted April 29, 2016 Author Share Posted April 29, 2016 Not really, if I only had the one rotation attribute in the block and then used an array on it the title of my thread wouldn't be Blocks with multiple attributes. Quote Link to comment Share on other sites More sharing options...
RobDraw Posted April 29, 2016 Share Posted April 29, 2016 Sometimes you need to help others help you. Sometimes people just don't interpret things correctly and you need to clarify. Just saying. Quote Link to comment Share on other sites More sharing options...
MrButtonmush Posted April 29, 2016 Author Share Posted April 29, 2016 Are you tactfully saying people don't read things properly lol. On a serious note though, it must be possible to make this work. I tried using the chaining option in the attribute properties but no combination made any difference! I'll admit though that perhaps the better definition would be can I have a block with multiple dynamic attributes Quote Link to comment Share on other sites More sharing options...
RobDraw Posted April 29, 2016 Share Posted April 29, 2016 Are you tactfully saying people don't read things properly lol. Sorry if not clear lol! Even you acknowledged it. Honestly, I didn't realize that the array was being applied within the block. I, and others, thought you were applying the array to the block after insertion and your use of the term attribute can mislead also as the annotation is not an attribute. Sorry I can't help you with that. I don't do much with dynamic blocks. Quote Link to comment Share on other sites More sharing options...
TheCADnoob Posted April 29, 2016 Share Posted April 29, 2016 Not really, if I only had the one rotation attribute in the block and then used an array on it the title of my thread wouldn't be Blocks with multiple attributes. Actually it was plenty confusing... then again im easily confused. Using terms like action and annotation as opposed to using attribute to describe an annotation might have helped me... but probably not... im kinda green From apperance you cant do what you are trying to do because of the way the array works. It basically arrays dumb geometry. This is why you cant array attributes, but you can array annotations. There are a couple approaches i might take if i were in your shoes. I would either use the array command, or i would create another block and and nest your rotate block in that one and make it array. The problem is that for one that you want the array in the block and the other would still require you exploding the array block. I think the best way to simulate what you want to do is to use visibility states. I would set up your common angles in visibility states and just use those instead of rotating. Quote Link to comment Share on other sites More sharing options...
TheCADnoob Posted April 29, 2016 Share Posted April 29, 2016 As a rider to this, i have seen visibility states chained with arrays and you could do this with your block and get your rotation that way. you would basically have to guess at the largest array that you imagine you would encounter and set up that many visibility states each with their own annotation rotation action associated with it. So i think your block as you desire is doable, though not quite simply and it would take more time and experience than i have at the moment. Quote Link to comment Share on other sites More sharing options...
steven-g Posted April 29, 2016 Share Posted April 29, 2016 I should also have said that after adjusting the array grip, you will need to regen the drawing, I tried your block the image on the left had the rotation applied after the array, the image on the right works by either performing the rotation first and then the array, or by just moving the array grip slightly (even clicking twice -not double click- on the array grip and then using regen worked for me). If I have misunderstood your problem then maybe an image showing what you want would help. However if you want each desk in the array to be independent, then the answer is no, that is not possible without having separate blocks. You could create a dynamic nested block so that the array worked on a dynamic block and after arraying then explode the result into individual blocks, and so goes the guessing game. As RobDraw says sometimes you need to give more help to get more help. Quote Link to comment Share on other sites More sharing options...
