Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 11 to 20 of 27
  1. #11
    Junior Member RichardLloyd's Avatar
    RichardLloyd's Computer Details
    Windows 7
    Mechanical
    RichardLloyd's Discipline Details
    Fire Sprinkler Designer
    Mechanical
    Sprinkler Fire Protection.
    AutoCAD LT 2014
    Jan 2014
    England, United Kingdom
    21
    I was mentioning it in relation to the post before that one ReMark. I will post the file up in a bit when I get on the computer, just on the tablet at the minute.
  2. #12
    Cad64's Computer Details
    Windows 7 Profesional x64
    XI Computers
    Asus P8Z77-V Pro
    24GB DDR3 @ 1333MHz
    SATAII 500GB 7200 RPM
    Asus VG248 24" Widescreen & Cintiq 21ux
    Multi-disciplinary
    Cad64's Discipline Details
    Freelance Digital Artist
    Multi-disciplinary
    3D model building, texturing and rendering. Photoshop Color Graphics.
    AutoCAD 2014
    Feb 2006
    San Antonio, TX
    10,315
    Sorry, I missed that you are using LT. Disregard my previous post.
    CGSociety Portfolio: http://rdeweese.cgsociety.org/
    Facebook:
    https://www.facebook.com/rdeweese67/
    "Work Smart, Not Hard"
  3. #13
    Forum Deity rkent's Avatar
    rkent's Computer Details
    WIN7 PRO 64bit
    Dell OptiPlex 7020
    i7 4790 3.6GHz
    16GB, 1600MHz, DDR3 non-ECC 2x8GB
    AMD Radeon 2GB
    Samsung 480Gb SSD
    Dell 24" FS (2x)
    Mechanical
    rkent's Discipline Details
    Mechanical
    Mechanical 2017
    Nov 2007
    4,598
    Working with the entire model in model space and then using mulitple viewports in paper space is very basic and how most folks work these days. As for getting an exact area in model space to be an exact viewport size in a layout is another matter and is probably not worth doing through coding.
    Here is what I do when I know I will have more than on viewport in layouts showing portions of the whole. From paper space I will get my title block inserted and then filled out. Create a viewport, get it scaled to the scale desired. Pan through the viewport to show the portion I want for this page. Adjust the size of the viewport to only show the model area for page 1. While still in page 1 and in PS create another viewport approximately the same size touching the first one. Use VPSYNC to exactly line up and scale the second viewport to the first one. Continue for the number of pages desired. LT may not have VPSYNC so see the alternate listed below which is almost as good.
    Finally copy the layout for the number of pages needed, rename those. Go to each one and delete the viewports not needed for each page, move the viewport inside the title block. Touch up each title block with the page number, description, etc.
    Instead of the VPSYNC command you can also copy the first viewport in place on top of itself. Then pick on it, grab the grips to the left side and pull beyond the right side which gives you a viewport lined up exactly where needed and of course at the correct scale. Continue however many times necessary.
    I think this is what you are after.
    Sometimes there's a man... I won't say a hero, 'cause, what's a hero? But sometimes, there's a man. And I'm talkin' about the Dude here. Sometimes, there's a man, well, he's the man for his time and place. He fits right in there. And that's the Dude, in Los Angeles. - The Stranger, The Big Lebowski
  4. #14
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,877
    This might work although it is a bit convoluted.
    In model space draw a box around the area you are interested in using a single continuous polyline. Copy it to the clipboard. Switch to your layout. Paste the box into the layout. Scale the box. Invoke the MVIEW command and using the Object option select the scaled box. Activate the viewport and find the box you created back in model space. Do a zoom > window picking two diagonal corners of the model space box. The model space box should now fill the entirety of the layout box.
    I could swear someone created a lisp routine that addresses your unique problem but I can't seem to locate the thread at the moment. I'll keep searching.
  5. #15
    Windows 7
    Mechanical
    Mechanical
    AutoCAD LT 2014
    Jan 2014
    21
    No worries Cad64, hopefully we will upgrade to full soon and I can start using code
  6. #16
    AutoCAD 2013
    Nov 2011
    6,056
    Might you be referring to this lisp by Lee Mac?
    http://www.lee-mac.com/vpoutline.html
    Thanks Lee!
  7. #17
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,702
    A similar to a box, is to pick a point as the centre in model then go to layout do a "enter scale", "zoom c adjusted scalefactor" and then a "zoom vpscale/xp", uses lisp to work out the variables.
  8. #18
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,877
    Quote Originally Posted by Dadgad View Post
    That's the one. Thanks Dadgad. My memory chips must be on low power. Think I need another cup of java to recharge them.
  9. #19
    Full Member
    Civil 3D 2013
    Apr 2014
    45
    This approach can convert layout with multiple viewports to multiple layouts, but in semi automatic way (need to give name to each layout and select appropriate objects for separation). Probably it can help you
  10. #20
    XI Computers
    Asus P8Z77-V Pro
    24GB DDR3 @ 1333MHz
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD 2014
    Feb 2006
    San Antonio, TX
    10,315
    The OP is using Autocad LT, so lisp routines will not work.
    Facebook:
  1. Moving object from Paper to Model across multiple Layouts
    By loopfish in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 2nd Jan 2016, 06:11 pm
  2. UCSFOLLOW with multiple viewports in model space.
    By Bogbadbob658 in forum AutoCAD General
    Last Post: 12th Nov 2011, 05:23 pm
  3. Multiple sheets. Single or multiple DWG files?
    By uhcafigdc in forum CAD Management
    Last Post: 15th Dec 2010, 02:01 pm
  4. Replies: 10
    Last Post: 14th Sep 2010, 10:24 am
  5. Good Question: Single vs. Multiple Layouts
    By AutoCAD Insider in forum AutoCAD RSS Feeds
    Last Post: 17th Jul 2007, 08:40 pm
Tags for this Thread
