wise-man Posted May 8, 2016 Share Posted May 8, 2016 (edited) I've drawn this frame, but I forgot how I made it but I think I used revolve or sweep command but how I forgot can anyone help me please :(:(:(:(:(:cry::cry::cry::cry: Edited May 8, 2016 by wise-man Quote Link to comment Share on other sites More sharing options...
halam Posted May 8, 2016 Share Posted May 8, 2016 Having a drinking problem..? ;-) I think you did some solid and boolean operations. A extrusion over a path, the bottom plate added later? Tip before the party starts.. always save the primitives. ;-) Quote Link to comment Share on other sites More sharing options...
paulmcz Posted May 8, 2016 Share Posted May 8, 2016 You drew a rectangle, filleted the corners, trimmed the half of it out, drew the cross section, extruded the cross section along the path of the filleted half-rectangle, copied the result, rotated the new copy by 180 deg, connected and joined the two pieces in union. Quote Link to comment Share on other sites More sharing options...
wise-man Posted May 8, 2016 Author Share Posted May 8, 2016 thx a lot guys dear halam no it's not drinking problem but I did it since long time the first step I drew 2d filleted rectangle and then drew an arc to help me to make a 3d curved frame with sweep or revolve command this step is forgotten the frame was one piece I didn't use union command and the bottom plate mostly added later by extrude the rectangle I'm not sure thx again so much Quote Link to comment Share on other sites More sharing options...
paulmcz Posted May 8, 2016 Share Posted May 8, 2016 It was just a wild guess from me but that's how I did it in about 2 minutes time, giving it no specific dimensions. Quote Link to comment Share on other sites More sharing options...
wise-man Posted May 9, 2016 Author Share Posted May 9, 2016 It was just a wild guess from me but that's how I did it in about 2 minutes time, giving it no specific dimensions. I will tell you how that is too easy bro I think now remember how I did it and all what I can tell you that I used sweep and arc Quote Link to comment Share on other sites More sharing options...
wise-man Posted May 9, 2016 Author Share Posted May 9, 2016 I did it guys but not in 2 minutes I did it in half minute and I will show you how first step as what I told you before I drew I filleted rectangle and then an arc and then used sweep ,select arc object and then select the filleted rectangle as a path and now done Quote Link to comment Share on other sites More sharing options...
halam Posted May 9, 2016 Share Posted May 9, 2016 Great!... Beer.. Quote Link to comment Share on other sites More sharing options...
Dadgad Posted May 9, 2016 Share Posted May 9, 2016 Are you trying to avoid making it into a 3D Solid? Instead of using an arc, you could have created a closed polyline, which when swept along your Path would have generated a 3D Solid, which is what I prefer to work with. Do you only want a Surface? If so, how you did it will suffice. Quote Link to comment Share on other sites More sharing options...
RobDraw Posted May 9, 2016 Share Posted May 9, 2016 Having a drinking problem..? ;-) dear halam no it's not drinking problem Great!... Beer.. ������ Great!... Beer.. Even after the OP said it wasn't a drinking problem? Really? Quote Link to comment Share on other sites More sharing options...
