Results 1 to 4 of 4
    Senior Member
    Architecture 2013
    Dec 2009
    123
    Default Autocad architecture - Ground surface modeling
    Hello all,
    What is the best and simple way to create a ground surface for a house. When the ground is meshed and it is possible to elevate some points up or down on the z exis. I know that this is available with Revit.
    I will appreciat short step by step instructions.
    Thanks
    Quantum Mechanic
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,131
    Pretty sure achitecture supports 3d faces so to make a simple surface create a series of POINTS using just that then with properties open select the point and add a Z, then just use 3dface type enter for the 4th face pt, triangles will appear that can be shaded etc.
    Senior Member
    Architecture 2013
    Dec 2009
    123
    Hello BIGAL,
    I will need to give it some thickness and assign materials to it and also divide it to several parts where one will be grass and another just soil and one will be path and so on. Also, each part (e.g. the path) will have several different height points.
    My question is what is the correct way to form this surface with Autocad Architecture.
    Thanks for your reply
    Senior Member
    Architecture 2013
    Dec 2009
    123
    Regarding this issue I have one specific question:
    When I create a mesh or a network or other ways of creating a surface that is marked with horizontal and vertical lines (such as mesh) I am not able to see all grip points within the surface where I can hold and move a certain point within of the surface up or down. Usually I get only 4 points in the corners (and of course usually these corners are far from the surface itself).
    Thanks for your support.
  1. I Need Help On Surface Modeling, AutoCAD 2002
    By spinecad in forum AutoCAD 3D Modelling & Rendering
    Last Post: 19th Mar 2013, 11:15 pm
  2. Ground shadows without a surface
    By Andrew Hayward in forum AutoCAD 3D Modelling & Rendering
    Last Post: 24th Mar 2011, 12:02 am
  3. 3d ground surface modelling
    By Snakeknuckles in forum AutoCAD 3D Modelling & Rendering
    Last Post: 18th Sep 2010, 07:18 pm
  4. Ground surface
    By cadgal in forum Architecture & ADT
    Last Post: 19th Apr 2010, 10:17 pm
  5. Surface modeling from AUTOCAD to INVENTOR ?
    By mclisme in forum Autodesk Inventor
    Last Post: 25th Sep 2007, 09:45 pm
