Results 1 to 6 of 6
    Senior Member bennyboy86's Avatar
    Structural
    bennyboy86's Discipline Details
    Structural Drafter
    Structural
    Revit 2015
    Jun 2011
    Sunshine Coast, Queensland, Australia
    117
    Question inserting PDF's into Revit
    Hello all,
    is it possible to insert PDF's into Revit as an underlay? from what I can find out its a big fat no, but wanted to check here. using revit 2015 release 13.
    Thanks all.
    Some people just need a high five.......to the face......with a chair!!!
    Super Member halam's Avatar
    AutoCAD 2017
    Jul 2015
    683
    No can do.
    AutoCAD can turn them into CAD First..
    Modelling is done with two hands, 2d & 3d. Let it work together..
    https://twitter.com/halammerts
    Luminous Being tzframpton's Avatar
    tzframpton's Computer Details
    HP Zbook
    Multi-disciplinary
    tzframpton's Discipline Details
    BIM Specialist
    Multi-disciplinary
    Full Virtual Design and Construction BIM services for the MEP engineering and construction industries.
    Revit 2019
    Mar 2006
    Dallas, TX - USA
    9,096
    Quote Originally Posted by bennyboy86 View Post
    Hello all,
    Thanks all.
    Halam is correct: Currently there is no PDF underlay/import support.
    Quote Originally Posted by halam View Post
    No can do.
    Just to clarify, AutoCAD 2017 can convert them to DWG if it's a vector PDF. If AutoCAD 2016 or older is being used this will not be possible. However, I use Inkscape which is a free application to import vector based PDF's and export to DXF, subsequently converting to DWG after open/inspect/scale (if necessary)/save.
    Also, converting to any common image format (PNG, TIFF, JPG) works in Revit but DWG is far better if possible.
    Tannar Z. Frampton ™ | Frampton & Associates, Inc.
    AutoCAD 2017
    Jul 2015
    683
    I am not very familiar with working with DWF but it should be the Autodesk alternative to work with it instead of PDF..
    Convert it to DWF and use this as underlay. Is this an option to consider Tannar?
  5. #5
    HP Zbook
    Multi-disciplinary
    BIM Specialist
    Multi-disciplinary
    Revit 2019
    Mar 2006
    Dallas, TX - USA
    9,096
    Halam, I have never tried DWF but I think it would be an interesting idea.
  6. #6
    Forum Newbie
    Architectural
    Revit Architecture 2017
    Jul 2017
    1
    simply convert pdf to jpeg first.
  1. Revit stand alone or Revit Suite Premium or Ultimate
    By Handiman in forum Revit General
    Last Post: 8th Apr 2016, 02:56 pm
  2. Revit Error - 'Autodesk.Revit.DB.Level'
    By C4C in forum Revit MEP
    Last Post: 2nd Feb 2016, 11:22 pm
  3. revit 2013 & revit mep are they the same?
    By paul1966 in forum Revit General
    Last Post: 6th Nov 2012, 08:07 pm
  4. Link Revit model into current revit model
    By miyuki_mll in forum Revit General
    Last Post: 2nd Nov 2009, 11:58 am
  5. inserting
    By DONALD KNAPP in forum AutoCAD Drawing Management & Output
    Last Post: 27th Jun 2007, 06:41 pm
