Madruga_SP Posted May 16, 2016 Share Posted May 16, 2016 Hi my friend, How are you? I'm trying to create a action to rotate the attribute, but I couldn't do that. Could you help me please? Thanks Fabricio test.dwg Quote Link to comment Share on other sites More sharing options...
Ski_Me Posted May 16, 2016 Share Posted May 16, 2016 I think this is what your looking for, I moved the attribute you created out of the way for clarity and added a new one. For some reason I couldn't select your attribute for a move parameter. If this happens then just delete it and create a new one with the same properties. What I did is placed a point in the middle of your block, then I created a move parameter and selected the point and the attribute. Next I picked the rotate parameter and selected the point but not the attribute this is important. Now I pick the point and go to properties and scroll to the bottom of the properties window and select chain actions. Now the attribute will rotate around the point and stay horizontal with respect to the x axis. If you unlock the attribute you can move it around after the rotate if you need to create some space between objects that might be in your way. Just go to block edit select the attribute go to properties and unlock the position. test1.dwg Quote Link to comment Share on other sites More sharing options...
Madruga_SP Posted May 17, 2016 Author Share Posted May 17, 2016 Hi Ski_Me Thank you very much. I've made some tests, and worked fine! If I have any doubts I let you know. Thanks Fabricio Quote Link to comment Share on other sites More sharing options...
