Results 1 to 5 of 5
    Junior Member
    AutoCAD 2015
    Mar 2016
    18
    Default Elevation P-F plate 4
    Hello all, first I want to say I love this forum,it has helped me with a lot of questions.
    My problem is I'm working on Plate 4 in structural drafting showing the e-w elevation.
    In the call outs it is saying that the concrete slab is 6" thick. I'm assuming for both the first and second floor. The problem I have is if I make the slab 6" and the clear distance from floor to ceiling of the first floor is 10' and for the second floor is 8'. the elevation is off. Am I reading the call outs right? or is the 6 " slab just for the first floor and the second floor is brought up to the elevation level?
    The other question involved with this is, are the elevations including the width of the ceiling tiles, which are 1/2" thick or is it just to the beams?
    Thank you.
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,865
    Information in Penn-Foster project instructions tends to be...
    1. Incorrect or...
    2. Ambiguous or...
    3. Missing.
    If you'll hold on a moment maybe I can provide you with an answer.
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,865
    Project 5 - Plate 4
    The distances of 10 feet and 8 feet respectively are from the top of floor slab to the bottom of the overhead beam or channel depending on which plate you are working on. The slab thickness is 6" as stated for both the ground floor and the floor above.
    Junior Member
    AutoCAD 2015
    Mar 2016
    18
    ok thank you so then that would be the elevation from the finish grade correct? Im just trying clarify.
  5. #5
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,865
    I am not on my CAD computer so I cannot confirm that but from what I recalled the top of slab elevation and finish grade were one in the same.
    Correction: The top of slab elevation for the ground floor is 293.90 and the finish grade is called out as being 292.90 (a difference of one foot). The information appears on page 11 of the project instructions. I am referring to the 054040.pdf file that another student posted here recently.
    There are threads specific to the project that contain images posted by other P-F students. Find one or more of them and have a look. Maybe you'll find an answer to your question.
  1. Surface elevation not matching contour elevation
    By JordanK in forum Civil 3D & LDD
    Last Post: 20th Sep 2014, 12:42 am
  2. I've Got A Plate In My Head!
    By Netminder in forum Autodesk Inventor
    Last Post: 18th Jul 2012, 08:26 pm
  3. Help with PLATE 3
    By paisis123 in forum AutoCAD Beginners' Area
    Last Post: 17th Jun 2011, 04:29 am
  4. Replies: 8
    Last Post: 20th Mar 2010, 11:42 am
