ebsoares Posted May 17, 2016 Share Posted May 17, 2016 Hi, all. Is there a way of importing a profile *.arg file (in the "Options"|"Profiles" tab) and have it simply change settings under the "Options"|"Files" tab and nothing else? I wouldn't mind going into the *.arg file and deleting lines, as long as I knew which ones were important. But would the profile import just fine if it did not have all the lines? For example, if I deleted everything in there that did not pertain to search paths, would it still load up? Right now, when we load a profile *.arg file it changes everything... the cursor size, background color, buttons, the way it selects elements, etc., and it would be very important that each user could upload a profile, based on which client standards one's working on that day, and have their customizations untouched. It might simply be that it can't be done, or i just don't know enough about profiles, but any help on this issue would be much appreciated. Thanks, Edgar Quote Link to comment Share on other sites More sharing options...
ebsoares Posted May 17, 2016 Author Share Posted May 17, 2016 Hi again. Just an update. I got an answer to this issue at a thread I posted on AUGI today: http://forums.augi.com/showthread.php?166272-Importing-AutoCAD-Profiles&p=1313228#post1313228 If profiles really can't be changed, I guess this closes the issue. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted May 18, 2016 Share Posted May 18, 2016 Have a look at this http://www.cadtutor.net/forum/showthread.php?69519-Adding-Folders-to-Support-File-Search-Path Quote Link to comment Share on other sites More sharing options...
