Results 1 to 6 of 6
    Junior Member
    AutoCAD 2013
    Feb 2016
    23
    Default Help with Penn Foster structural drafting 054040
    I do not understand how i must draw plate 3. I dont even know where to start.054040.pdf(starts on page 16) Can i please have help understanding this?
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,721
    Drafting section "A" - Plate 3 begins on page 14.
    You are drawing a building in section. In other words the building has been cut in half length-wise and your job is to draw what it would look like. Start with the footings, piers and concrete slab then work your way up from there by adding the building columns and beams.
    There are other threads where this project is discussed and some of them contain images of most if not all of the plates. Take a look at them.
    If you have further questions post back. Good luck.
    Junior Member
    AutoCAD 2013
    Feb 2016
    23
    So first of all ReMark, thank you for unknowingly helping me through the Oleson Village subdivision project a few months ago, i got 100% on that test thanks to you. also i will keep searching through the forums for other threads about this plate 3. Now just one question though, are you saying that what i need to draw is something like plate 2 except i will be showing the other wall?
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,721
    Plate 2 called for the student to draw an elevation not a section.
    Leave your house or apartment and go outside. Turn around and look back. What you see is an elevation. A section is a cut through a building or an object. Understand? Some elements of both will be similar but others will be different. If you cut your residence in half you would see such things as beams, studs, flooring, insulation, joists, rafters, etc. that would not be seen in elevation. In an elevation you would see the exterior details like the roof shingles, chimney, exterior cladding (brick, vinyl siding, clapboard, etc.), gutter/downspout and trim around the windows.
  5. #5
    Junior Member
    AutoCAD 2013
    Feb 2016
    23
    thank you!
  6. #6
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,721
    Poking around this morning I came across what I believe is an image of Plate 3 in this thread.
    http://www.cadtutor.net/forum/showth...ht=Penn-Foster
    BTW...after reading through the .pdf file you attached previously it appears that Penn-Foster is basically using the same set of instructions they did several years ago which you will find to be missing pertinent information, prone to errors and containing misinformation. On top of that they continue to instruct students to draw their title block and border at full size, in model space, then scale it up to fit around the drawing. OMG. What year is this? 1985?? Still no mention of using a paper space layout and a viewport. In my opinion students are getting ripped off.
  1. Penn Foster Drafting with AutoCad Structural help with the rebar.
    By Hondatek in forum Student Project Questions
    Last Post: 17th Sep 2015, 01:05 am
  2. Penn Foster Drafting with AutoCad Structural grade report.
    Last Post: 24th Feb 2015, 06:14 pm
  3. Penn Foster Structural Plate 4
    By wendymoose in forum Student Project Questions
    Last Post: 15th Feb 2015, 12:17 am
  4. Penn Foster Structural drafting
    By redcav01 in forum Student Project Questions
    Last Post: 30th Dec 2012, 05:01 pm
  5. Structural drafting project Plate 2 (penn foster)
    By ANC2008 in forum Student Project Questions
    Last Post: 13th Jul 2011, 11:47 pm
Tags for this Thread
