mknj61 Posted May 20, 2016 Share Posted May 20, 2016 Hello maybe someone can help me with this. I'm trying to draw a break line and I use the command and when I insert the break line at midpoint it appears very wide. I've tried to adjust the size but it doesn't change the width. I attached a screen shot of what I am getting. I'm using the size as 1/8". I had tried adjusting the size bu no change. Break Line.docx Quote Link to comment Share on other sites More sharing options...
BIGAL Posted May 20, 2016 Share Posted May 20, 2016 Search for breakline.lsp there should be lots of examples that you can fine tune if not happy with the built in one. Quote Link to comment Share on other sites More sharing options...
ReMark Posted May 20, 2016 Share Posted May 20, 2016 My guess is that 1) You are zoomed in way to tight and 2) your breakline size is way too small. Look at the command line. When the BREAKLINE command is started you are provided with the following information: Block= BRKLINE.DWG, Size= 1/2", Extension= 1 1/4" Specify first point for breakline or [block/Size/Extension]: Type "S" (without the quotation marks) for Size, press the Enter key, and try using a value of 5. You can ignore the Extension option for the moment. Then continue on with the command as you normally would. What was the result? BTW....I've already tested this approach so I know what will happen. Quote Link to comment Share on other sites More sharing options...
mknj61 Posted May 20, 2016 Author Share Posted May 20, 2016 I got it figured out thanks. Quote Link to comment Share on other sites More sharing options...
RobDraw Posted May 20, 2016 Share Posted May 20, 2016 I got it figured out thanks. What was your solution? Quote Link to comment Share on other sites More sharing options...
