Script For Printing
DennisK2579
What we have is a directory full of drawings some are model some are layout.
Right now I can open and run a script depending which space the drawing is.
What we are looking for is having a script take that directory and open each drawing and depending what space it is creates the pdf for us. Instead of opening each drawing and having two scripts.
Thanks
dk
How about taking the approach of making sure all drawings are set-up the same, like a good drafter should?
Having a standard set-up saves a lot of headaches.
I have lisps to plot either layout or model which finds all "title blocks" in model but how would I decide which is correct space to plot, only idea is that layout must be one only and have nothing in it. Like robdraw you must have strict rules to automate this. You can have a master script that checks model or layout then loads correct 2nd lisp.
PUBLISH command?
Also suggest using Sheet Set Manager, which makes PDF, DWFx & general plotting whole projects much quicker.
