Results 1 to 3 of 3
Thread: Scaling
    Junior Member
    AutoCAD 2015
    Mar 2016
    18
    Default Scaling
    Hello again, Im working on the structural project 5 plate 6. the only thing Im having trouble with is the scaling. Maybe I didn't do it right on the other plates.
    In the beginning of the instructions we have to draw up an 11" x 17" title block which will be used for the plates.The instructions say to enlarge the title block or scale up the title block to use around the drawings. And then on the plate specify what the scale is.
    My question is this. I know in model space everything is drawn 1:1, Im not clear as to how to scale the title block, and in plate 6, the scale is 1/2":1'. Does the drawing change to that scale when I change it? Or is it just the dimensions that are changed?
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,865
    You are going to use the SCALE command to enlarge the 11x17 to fit around the drawing. Since the designated scale happens to be 1/2"=1'-0" then the scale factor will be 24. You are NOT scaling what you have already drawn...just the title block and border. Understand?
    Junior Member
    AutoCAD 2015
    Mar 2016
    18
    Yes I understand thank you again
  1. Axis scaling: Scaling parts of an object, but not the whole thing
    By jpaulgayjr in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 14th Mar 2014, 08:15 pm
  2. Scaling
    By Lucy1 in forum AutoCAD Beginners' Area
    Last Post: 31st Aug 2011, 12:21 am
  3. HELP! Scaling.
    By adelineowl in forum AutoCAD Drawing Management & Output
    Last Post: 28th Jun 2011, 07:33 pm
  4. scaling
    By bjenk8100 in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 21st Oct 2010, 06:57 pm
  5. Scaling to plot and scaling bar
    By john551 in forum AutoCAD Beginners' Area
    Last Post: 2nd Oct 2009, 06:01 pm
