+ Reply to Thread
Page 1 of 7 1 2 3 ... LastLast
Results 1 to 10 of 61
  1. #1
    Forum Newbie
    Using
    AutoCAD 2008
    Join Date
    Nov 2009
    Posts
    5
    Default -Penn Foster? HVAC transition piece
    Hello! Does Any One Know How To Draft A 10"x14"x6" RECTANGULAR Hvac Pattern
    THATS 14"X6" ON ONE SIDE AND10"X6" ON THE OTHER
  2. #2
    Super Member Tankman's Avatar
    Computer Details
    Tankman's Computer Details
    Operating System:
    XP Pro SP3
    Computer:
    IBM T60 Thinkpad™
    Monitor:
    36" LCD Monitor/TV, 14" Thinkpad™ T60
    Using
    AutoCAD 2007
    Join Date
    Mar 2008
    Location
    Eastern PA, USA
    Posts
    1,796
    Default
    Welcome to the forums drafterjohn! Where might you be posting from?
    10x14x6 pattern?
    10" x 14" rectangle x 6" high?
    10"Ø x 14"Ø x 6" high?
    Need to know more.
    I started working in sheetmetal, duct work, over 40 years ago.
    A worthwhile and satisfying trade.
    All kinds of worthwhile reference material available at The Sheetmetal Shop.
    http://www.thesheetmetalshop.com/pn/...isplay&pid=142
    Tankman
    "When the well is dry, we know the worth of water." Ben Franklin ~ 1746
  3. #3
    Forum Newbie
    Using
    AutoCAD 2008
    Join Date
    Nov 2009
    Posts
    5
    Default
    Hello! Tankman Are You There, I Sure Use Your Help If You Can Help Me
    I Am Riquired To Draw A 2d Hvac Pattern That Is 14" X6"rectangular On One End And 10"x6" Rectangular On The Other End . Any Help From You Will Be Greatly Appreciated
  4. #4
    Forum Newbie
    Using
    AutoCAD 2008
    Join Date
    Nov 2009
    Posts
    5
    Default
    Hay Sorry I Miss Your ? There Iam Posting From Reading, Pa.
  5. #5
    Computer Details
    Operating System:
    XP Pro SP3
    Computer:
    IBM T60 Thinkpad™
    Monitor:
    Using
    AutoCAD 2007
    Join Date
    Mar 2008
    Location
    Eastern PA, USA
    Posts
    1,796
    Default
    Quote Originally Posted by drafterjohn773 View Post
    Hay Sorry I Miss Your ? There I am posting From Reading, Pa.
    Posting from Perkasie, PA 'bout 15 miles south of the triple duce, south of Allentown, PA.
    Take a peek-a-boo at the attached *.dwg file.
    Lots would depend on sheetmetal gauge and, how do you want to assemble the transition?
    If small gauge sheetmetal, easy enough to add 1/2" flanges for spotwelding two pieces together to make the transition.
    Tankman
  6. #6
    Computer Details
    Operating System:
    XP Pro SP3
    Computer:
    IBM T60 Thinkpad™
    Monitor:
    Using
    AutoCAD 2007
    Join Date
    Mar 2008
    Location
    Eastern PA, USA
    Posts
    1,796
    Default
    John:
    Added a bit to the sketch (drawing). Sitting here, just watched the Eagles choke again. Ouch.
    I didn't note the bend angles, easy enough.
    I did add 1/2" flanges for spot welding, again, don't know how you want to secure this transition. I also don't know the gauge you're working with. I am assuming light gauge HVAC ductwork.
    The top bends will be over 90°, the bottom (10" x 14") bends will be under 90°.
    Comments welcome.
    Tankman
  7. #7
    Forum Newbie
    Using
    AutoCAD 2008
    Join Date
    Nov 2009
    Posts
    5
    Default
    054042.pdftankman i think you very much for your help, light bulbs are starting to flick on now;however i would like to snd you a copy of the instructions that was given to concerning how to go about drawing this transition piece. please take a look at it and send feed back.
    drafterjohn
  8. #8
    Computer Details
    Operating System:
    XP Pro SP3
    Computer:
    IBM T60 Thinkpad™
    Monitor:
    Using
    AutoCAD 2007
    Join Date
    Mar 2008
    Location
    Eastern PA, USA
    Posts
    1,796
    Default
    John:
    I'll take a peek at your *.pdf sometime today.
    At first glance, very nice.
    We must also take note, there's always another way to complete the project.
    There's always more than one way to complete an AutoCAD layout too!
    Tankman
  9. #9
    Luminous Being tzframpton's Avatar
    Computer Details
    tzframpton's Computer Details
    Computer:
    HP Zbook
    Discipline
    Multi-disciplinary
    tzframpton's Discipline Details
    Occupation
    BIM Specialist
    Discipline
    Multi-disciplinary
    Details
    Full Virtual Design and Construction BIM services for the MEP engineering and construction industries.
    Using
    Revit 2019
    Join Date
    Mar 2006
    Location
    Dallas, TX - USA
    Posts
    9,117
    Default
    When you mean "pattern" are you meaning you need to create a flat pattern that will be fed to a plasma or cutter? Or do you just need to represent a transition dimensionally so that a fab shop can produce the transition for you?
    Tannar Z. Frampton ™ | Frampton & Associates, Inc.
  10. #10
    Luminous Being JD Mather's Avatar
    Using
    Inventor 2015
    Join Date
    Sep 2007
    Location
    Williamsport, PA
    Posts
    8,731
    Default
    How far between ends?
    Certified SolidWorks Professional
    Autodesk Inventor 2015 Certified Professional
    Autodesk AutoCAD 2013 Certified Professional
Similar Threads
  1. Penn Foster
    By bracken2 in forum Student Project Questions
    Last Post: 9th Aug 2011, 11:11 pm
  2. Now WHAT IS THIS!> penn foster help!
    By paisis123 in forum Student Project Questions
    Last Post: 4th Aug 2011, 09:02 pm
  3. Penn Foster help with HVAC/sheet metal Drafting
    Last Post: 15th Jun 2011, 10:19 pm
  4. Transition Piece patterns
    By engineer1 in forum Autodesk Inventor
    Last Post: 2nd May 2006, 02:17 pm
  5. HVAC transition piece
    By engineer1 in forum AutoCAD Beginners' Area
    Last Post: 3rd Apr 2006, 09:34 pm
Posting Permissions
  • You may not post replies
  • You may not edit your posts
