+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 10 of 15
  1. #1
    Forum Newbie
    Using
    AutoCAD 2013
    Join Date
    May 2016
    Posts
    8
    Default orthographic to isometric help
    Hi,
    I am trying to draw an isometric version of this part from first angle orthographic projections. But I just can't do it
  2. #2
    Computer Details
    ReMark's Computer Details
    Operating System:
    Windows 7 Pro 64-bit
    Computer:
    Thinkmate
    Motherboard:
    Intel DX58SO2 LGA1366 X58
    CPU:
    RAM:
    12GB (3x4GB) PC3-106000 DDR3
    Graphics:
    Primary Storage:
    Secondary Storage:
    none
    Monitor:
    Discipline
    See details...
    ReMark's Discipline Details
    Occupation
    Discipline
    See details below.
    Details
    Using
    AutoCAD 2018
    Join Date
    Nov 2005
    Location
    Norwalk, CT USofA
    Posts
    46,839
    Default
    Save yourself the headache and create a 3D model then derive the 2D isometric from the model. So much easier.
    However, if you insist on doing it in 2D remember you'll need to use the ELLLIPSE command's Isocircle option.
    OK...here is my rough approximation, given that no dimensions were provided, of what the object would look like as a 3D model using a standard SE isometric view.
    And these 2D views, derived via the FLATSHOT command, basically support my premise.
    Hope this helps. Good luck.
  3. #3
    Computer Details
    Operating System:
    Computer:
    Thinkmate
    Motherboard:
    CPU:
    RAM:
    Graphics:
    Primary Storage:
    Secondary Storage:
    none
    Monitor:
    Discipline
    See details...
    Occupation
    Discipline
    See details below.
    Details
    Using
    AutoCAD 2018
    Join Date
    Nov 2005
    Location
    Norwalk, CT USofA
    Posts
    46,839
    Default
    Thought these two images might be of use. One with and one without hidden lines.
  4. #4
    Computer Details
    Operating System:
    Computer:
    Thinkmate
    Motherboard:
    CPU:
    RAM:
    Graphics:
    Primary Storage:
    Secondary Storage:
    none
    Monitor:
    Discipline
    See details...
    Occupation
    Discipline
    See details below.
    Details
    Using
    AutoCAD 2018
    Join Date
    Nov 2005
    Location
    Norwalk, CT USofA
    Posts
    46,839
    Default
    Shadowblitz: Have you made any progress on your 2D isometric?
    No response? Did you decide to drop the course instead?
  5. #5
    Forum Newbie
    Using
    AutoCAD 2013
    Join Date
    May 2016
    Posts
    8
    Default
    Quote Originally Posted by ReMark View Post
    I'm terribly sorry for my uber late response but yeah thanks a lot for helping out,
    also I managed to pass that course but now Im now taking its prerequisite and our dick of an instructor never really teach us anything, just hands out plates after plates
    we're now at making cross sectional views and have a new plate that I need some help on lol
  6. #6
    Computer Details
    Operating System:
    Computer:
    Thinkmate
    Motherboard:
    CPU:
    RAM:
    Graphics:
    Primary Storage:
    Secondary Storage:
    none
    Monitor:
    Discipline
    See details...
    Occupation
    Discipline
    See details below.
    Details
    Using
    AutoCAD 2018
    Join Date
    Nov 2005
    Location
    Norwalk, CT USofA
    Posts
    46,839
    Default
    So what is the problem? Should be easy to create a cross section using the SECTIONPLANE command. Or, if you want to, you can create the 3D model and cut the section(s) yourself using the Object or the Surface option of the SLICE command. You should learn/practice all options so you have a good understanding of which works best for any given situation.
  7. #7
    Forum Newbie
    Using
    AutoCAD 2013
    Join Date
    May 2016
    Posts
    8
    Default
    drawing the top and sectional view like this
    thanks for the tips, will try to practice/learn more
  8. #8
    Forum Newbie
    Using
    AutoCAD 2013
    Join Date
    May 2016
    Posts
    8
    Default
    also we have to rotate the figure so the x becomes a vertical cross
  9. #9
    Computer Details
    Operating System:
    Computer:
    Thinkmate
    Motherboard:
    CPU:
    RAM:
    Graphics:
    Primary Storage:
    Secondary Storage:
    none
    Monitor:
    Discipline
    See details...
    Occupation
    Discipline
    See details below.
    Details
    Using
    AutoCAD 2018
    Join Date
    Nov 2005
    Location
    Norwalk, CT USofA
    Posts
    46,839
    Default
    Quote Originally Posted by shadowblitz3 View Post
    You should know how to rotate a 3D model already.
    How to rotate a 3D object around an axis...https://knowledge.autodesk.com/suppo...0DFD8-htm.html
  10. #10
    Computer Details
    Operating System:
    Computer:
    Thinkmate
    Motherboard:
    CPU:
    RAM:
    Graphics:
    Primary Storage:
    Secondary Storage:
    none
    Monitor:
    Discipline
    See details...
    Occupation
    Discipline
    See details below.
    Details
    Using
    AutoCAD 2018
    Join Date
    Nov 2005
    Location
    Norwalk, CT USofA
    Posts
    46,839
    Default
    Attachment 58565
    AutoCAD SECTIONPLANE command... https://knowledge.autodesk.com/suppo...B55EA-htm.html
Similar Threads
  1. Orthographic to Isometric help
    By dantheman in forum AutoCAD Beginners' Area
    Last Post: 2nd Nov 2012, 01:40 am
  2. orthographic projections??
    By megamind in forum Student Project Questions
    Last Post: 24th Feb 2012, 06:33 pm
  3. Orthographic Projection
    By JD Mather in forum AutoCAD Drawing Management & Output
    Last Post: 14th Dec 2007, 09:23 pm
  4. orthographic pan
    By qball in forum AutoCAD Drawing Management & Output
    Last Post: 14th Mar 2007, 07:43 pm
  5. Orthographic to Isometric?
    By snowbelt in forum AutoCAD Drawing Management & Output
    Last Post: 18th Jul 2005, 03:07 am
Posting Permissions
  • You may not post replies
  • You may not edit your posts
