+ Reply to Thread
Page 2 of 2 FirstFirst 1 2
Results 11 to 15 of 15
  1. #11
    Computer Details
    ReMark's Computer Details
    Operating System:
    Windows 7 Pro 64-bit
    Computer:
    Thinkmate
    Motherboard:
    Intel DX58SO2 LGA1366 X58
    CPU:
    RAM:
    12GB (3x4GB) PC3-106000 DDR3
    Graphics:
    Primary Storage:
    Secondary Storage:
    none
    Monitor:
    Discipline
    See details...
    ReMark's Discipline Details
    Occupation
    Discipline
    See details below.
    Details
    Using
    AutoCAD 2018
    Join Date
    Nov 2005
    Location
    Norwalk, CT USofA
    Posts
    46,877
    Default
    Two top views and a section. In this example I copied the 3D model then created a section using the SLICE command > Surface option. I used the 3DROTATE command to rotate the section into the correct position. Visual style = Conceptual.
    Another link for you re: creating sectional views using the BASEVIEW command. Note that this command places the blocks that are created in a layout and not in model space. You could also use the combination of two commands SOLVIEW and SOLDRAW to do something similar but I think BASEVIEW is much simpler.
    http://www.cad-notes.com/autocad-201...-detail-views/
  2. #12
    Forum Newbie
    Using
    AutoCAD 2013
    Join Date
    May 2016
    Posts
    8
    Default
    Quote Originally Posted by ReMark View Post
    Attachment 58566
    again thanks a lot for your help, will really try to learn all this and make them myself for a change
  3. #13
    Senior Member lrm's Avatar
    Computer Details
    lrm's Computer Details
    Operating System:
    Windows 7 64-bit
    RAM:
    16 GB
    Discipline
    Education
    lrm's Discipline Details
    Occupation
    Teacher, AEC and mechanical
    Discipline
    Education
    Details
    Civil and Mechanical
    Using
    3ds Max 2017
    Join Date
    Jan 2010
    Location
    Massachusetts, USA
    Posts
    380
    Default
    Actually, these are THIRD angle projections used in the USA. The ROW (rest of world) uses first angle projections which would put your top view below the front view.
  4. #14
    Computer Details
    Operating System:
    Computer:
    Thinkmate
    Motherboard:
    CPU:
    RAM:
    Graphics:
    Primary Storage:
    Secondary Storage:
    none
    Monitor:
    Discipline
    See details...
    Occupation
    Discipline
    See details below.
    Details
    Using
    AutoCAD 2018
    Join Date
    Nov 2005
    Location
    Norwalk, CT USofA
    Posts
    46,877
    Default
    Thanks for the primer but I was not demonstrating how to set up orthographic views. It was merely to show the rotation of the 3D model and a section cut through it.
  5. #15
    Computer Details
    Operating System:
    Windows 7 64-bit
    RAM:
    16 GB
    Discipline
    Education
    Occupation
    Discipline
    Education
    Details
    Using
    3ds Max 2017
    Join Date
    Jan 2010
    Location
    Massachusetts, USA
    Posts
    380
    Default
    ReMark, my comment was aimed at the OP. As a student he should know the difference between first and third angle projections. I know you know better!
Similar Threads
  1. Orthographic to Isometric help
    By dantheman in forum AutoCAD Beginners' Area
    Last Post: 2nd Nov 2012, 01:40 am
  2. orthographic projections??
    By megamind in forum Student Project Questions
    Last Post: 24th Feb 2012, 06:33 pm
  3. Orthographic Projection
    By JD Mather in forum AutoCAD Drawing Management & Output
    Last Post: 14th Dec 2007, 09:23 pm
  4. orthographic pan
    By qball in forum AutoCAD Drawing Management & Output
    Last Post: 14th Mar 2007, 07:43 pm
  5. Orthographic to Isometric?
    By snowbelt in forum AutoCAD Drawing Management & Output
    Last Post: 18th Jul 2005, 03:07 am
Posting Permissions
  • You may not post replies
  • You may not edit your posts
