Results 1 to 7 of 7
    Senior Member
    AutoCAD 2010
    Apr 2011
    145
    Default Lisp to set plot up
    Hi Guys I came across the following routine, from https://forums.autodesk.com/t5/forum...e/false/page/2
    However, when I tried it it gives me an error message ; error: no function definition: LM:ODBX
    How can I get this to work and also change the default size to A1 rather than A2.
    Code:
    (defun c:RV ( / )
        (LM:ODBX
            (function
                (lambda ( doc )
    		(princ (strcat "\nOpening file : "(vla-get-name doc)))
    		(vlax-for lay (vla-get-layouts doc)
    			; (if ( = "Model" (vla-get-name lay))
    				; (progn
    				(setq PaperSize "ISO_A2_(594.00_x_420.00_MM)");-----default paper size
    				(princ "\nSearching for Title Block")
    				(vlax-for blk (vla-get-blocks doc)
    				(cond
    					(( = (vla-get-name blk) "Title_A4") (setq PaperSize "ISO_A4_(297.00_x_210.00_MM)"))
    					(( = (vla-get-name blk) "A3 Drawing Sheet") (setq PaperSize "ISO_A3_(420.00_x_297.00_MM)"))
    					(( = (vla-get-name blk) "Title_A2") (setq PaperSize "ISO_A2_(594.00_x_420.00_MM)"))
    					(( = (vla-get-name blk) "Title_A1") (setq PaperSize "ISO_A1_(841.00_x_594.00_MM)"))
    				);cond
    				);vlax-for blocks
    				(princ (strcat "\nPaper Size Assigned : " PaperSize))
    				; );progn
    			; );if model space
    			(vla-put-ConfigName lay "DWG To PDF.pc3")	;set the plotter
    			(vla-put-CanonicalMediaName lay PaperSize)		;set the paper size--->
    			(vla-put-PlotType lay "1")			;plot area extens
    			(vla-put-CenterPlot lay "1")			;center plot
    			(vla-put-PaperUnits lay "1")			;set units to mm
    			(vla-put-PlotWithLineweights lay "0")		;turn off lineweights
    			(vla-put-PlotWithPlotStyles lay "1")		;turn on plot styles
    			(vla-put-StandardScale lay "0")			;fit to paper
    			(vla-put-stylesheet lay "Grayscale.ctb")	;set  the CTB
    			(princ (strcat "\nPlot settings done for : "(vla-get-name lay)))
    		);vlax-for
    		(princ "\n--------------------------------------------------")
            nil t
    );defun
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,721
    Re: change default paper size. Wouldn't you just substitute "ISO_A1_(841.00_x_594.00_MM)") for "ISO_A2_(594.00_x_420.00_MM)") where it says (setq PaperSize...default paper size? Can't help you with the first question. Sorry.
    Super Member
    Civil 3D 2015
    Aug 2015
    508
    In general, if you see a function that starts with LM: it will have been created by Lee Mac because that is his signature he puts on nearly all functions (you can also bet that it will be an awesome function because he is the master of all things LISP haha). That function can be found on his website http://www.lee-mac.com/odbxbase.html.
    Senior Member
    AutoCAD 2010
    Apr 2011
    145
    Thanks Broncos15 will have a look into Lee's site
  5. #5
    Lee Mac's Computer Details
    Windows 7 Ultimate (32-bit)
    Multi-disciplinary
    Lee Mac's Discipline Details
    Multi-disciplinary
    AutoCAD 2013
    Aug 2008
    London, England
    19,454
    Quote Originally Posted by broncos15 View Post
    Haha! Thanks broncos
    Lee Mac ProgrammingTwitterExchange App StoreDropbox (500MB free)
  6. #6
    Senior Member
    AutoCAD 2010
    Apr 2011
    145
    Hi Lee,
    Any ideas why that lamda function is not functioning as it should?
  7. #7
    Quantum Mechanic
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,141
    My $0.05 went a slightly different way just have a pull down menu with the various plot sizes and destination printer hard coded rather than select. Pick option 20 sheets come out etc.
  1. Batch plot Lisp?
    By CadTechJGC184 in forum AutoLISP, Visual LISP & DCL
    Last Post: 4th Dec 2013, 05:17 pm
  2. Plot all layouts using custom plot lisp
    By woodman78 in forum AutoLISP, Visual LISP & DCL
    Last Post: 24th Apr 2012, 01:20 pm
  3. Help with PDF plot lisp
    By nlao in forum AutoLISP, Visual LISP & DCL
    Last Post: 15th Jun 2011, 12:43 pm
  4. Plot current layout without entering name is lisp plot string
    By hosannabizarre in forum AutoLISP, Visual LISP & DCL
    Last Post: 8th Apr 2011, 01:43 pm
  5. lisp plot?
    By lewis770227 in forum AutoLISP, Visual LISP & DCL
    Last Post: 24th Mar 2009, 09:57 pm
Tags for this Thread
