Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 24
    Forum Newbie
    AutoCAD 2016
    May 2016
    5
    Default Bizarre Cube Problem
    Dear All,
    I am new to the forum so thanks in advance.
    My problem is this I have been asked to create an artistic cube drawing which is 1 metre square, then I have to insert 100 separate holes right through all 3 (6) faces, there is 100 holes in all starting at 1mm then 2mm, 3mm... and so on through to 100mm.
    Would there be a formula for this does anyone know?
    Really appreciate any input on this nutty problem.
    Campaigner
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,878
    I'm assuming this is all to be done in 3D right?
    Is the cube supposed to solid throughout or is it hollow?
    Why would you need a formula to create the holes?
    Is there a pattern that must be followed for the placement of the holes or can they be placed at random intervals?
    Final result will depict each face with 100 holes right?
    AutoCAD 2013
    Nov 2011
    6,056
    How about just using the Artistic metric cube with body piercings lisp?
    Welcome to the CADTutor forum Campaigner.
    Sorry, I couldn't resist.
    I don't suggest you waste any time googling for such a lisp.
    So, as ReMark asked, will the total number of holes be 100, or 100 per axis, for a total of 300 holes?
    Have you considered, or been given, a concept for the hole layouts on the faces?
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,715
    A 1m cube with tubes took about 2 mins. If you do 1mm 2mm 3mm say across you will get 5050 not 1000 so would need some form of radial from a corner formula to do 1mm 2mm 3mm etc a sprialing centre of the circle. Image is just an array example.
  5. #5
    Forum Newbie
    AutoCAD 2016
    May 2016
    5
    The cube will have the 100 holes randomly scattered across each face - on all 3 planes. The reason a formula may be required as at a later date not only will the cube size be changing but also the number of holes. The cube will be 3D printed. Already impressed with the answers...
  6. #6
    AutoCAD 2013
    Nov 2011
    6,056
    I thought from your original post that a single cube would have 100 holes, and that no two holes would be of the same diameter?
    Meaning ranging in increments of one mm from 1 to 100?
    And they will randomly pierce the cube along each of the ortho axii, X, Y & Z.
    Are the holes allowed to intersect one another inside the cube?
  7. #7
    Forum Newbie
    AutoCAD 2016
    May 2016
    5
    ...that's right Dadgad, each face will have 100 holes, no two holes will be the same diameter, they will be a series of 1-100. If they are random they will be allowed to intersect with each other.
  8. #8
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,878
    Quote Originally Posted by Campaigner View Post
    Any other criteria you care to add?
    So, what's with the question about a formula? You still haven't provided an explanation.
  9. #9
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,878
    Here's my first attempt at what I refer to as my Cube of Swiss Cheese.
    My 100 holes were systematically positioned across a single face of the cube at a spacing of 100mm horizontally and vertically in ascending order starting at 1mm then proceeding all the way up to 100mm. I won't bother going into an explanation of the process I used unless someone is interested other than to say the holes were then copied to the other two orientations.
  10. #10
    Forum Deity SEANT's Avatar
    AutoCAD 2014
    Aug 2005
    Rhode Island
    2,463
    I certainly think it possible to automate that task with Lisp, or some such. It would not neccessarily be easy. The random placement has to avoid already placed holes.
    Perhaps a little human interaction would be okay. This command macro was used to create the attached file:
    *^C^C_Circle;\D;$M=$(getvar,useri1);setvar;useri1; $(-,$(getvar,useri1),1);
    A portion of the process was screen captured here:
    https://knowledge.autodesk.com/commu...0-dbb61a0882ec
    HundredCircles.dwg
  1. Bizarre problem with zoom extents
    By Feyd313 in forum AutoCAD Drawing Management & Output
    Last Post: 28th Apr 2015, 08:01 pm
  2. Replies: 3
    Last Post: 29th Jul 2014, 11:05 am
  3. Bizarre text
    By dfield in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 8th Jan 2013, 07:36 pm
  4. 3d face on a bizarre shape
    By sarah in forum AutoCAD 3D Modelling & Rendering
    Last Post: 24th Feb 2009, 03:17 pm
  5. Bizarre Printing Problem
    By Fritz in forum AutoCAD Drawing Management & Output
    Last Post: 15th Oct 2008, 10:18 pm
Tags for this Thread
