cad 2017
hila
HI all,
I am having problems with the 2017 version, I used to use 2013, and now every new element i place, line, rectangle etc. it gives me the X/Y mark in a little box next to the element I drew,
Its driving me crazy!! what do I have to switch off for it to stop?????
You wouldn't happen to have Constraints enabled would you? Sorry, not at my CAD computer to verify at the moment.
As remark suggested those are constraints. The tools for handling those are in the parametric tab. if you dont have that you will have to show it by right click on it and selecting it from the list of avaliable tabs
Once there you can show and hide etc or delete with the tools there.
I believe AutoCAD comes configured with constraints enabled as the default. You'll have to delete the ones you have first then disable the feature. Both actions are described in the AutoCAD Help file and have been discussed here in several similar threads.
