Results 1 to 4 of 4
    Forum Newbie
    Inventor 2017
    Jun 2016
    1
    Default Dimensioning Problem
    I am learning Autodesk Inventor and am having trouble adding a certain dimension to a slot to a product I am embedding into a 2D sketch.
    Attached is a screenshot that portrays the issue I am facing. Thank you in advance for your assistance.
    AutoCAD 2013
    Nov 2011
    6,048
    Welcome to CADTutor.
    Sorry I can't answer your question, as I don't use Inventor, but Inventor questions should be posted in the Inventor Forum, thus increasing the likelihood that Inventor users will see them, and respond.
    If I read your post correctly, it sounds like you haven't modeled the slotted hole into your model?
    Which seems different than how I would expect it to be done.
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,094
    I moved your thread to the Autodesk Inventor Forum, please post your Inventor questions here from now on.
    Senior Member
    gbradley's Computer Details
    WIndows 7 64 Bit
    HP Z400
    24 Gig
    Invidia
    Inventor 2018
    Sep 2008
    So Cal
    122
    Use Centered Pattern
    Good luck!
  1. 3D dimensioning problem
    By MinaRAI in forum AutoCAD 3D Modelling & Rendering
    Last Post: 21st Aug 2014, 06:44 am
  2. problem with dimensioning
    By abkb12 in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 15th Jul 2014, 08:32 pm
  3. dimensioning problem
    By pvd in forum Autodesk Inventor
    Last Post: 1st Jul 2009, 05:07 pm
  4. Dimensioning Problem
    By Pema Lama in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 6th Mar 2008, 07:54 pm
  5. Dimensioning problem
    By joejoejoe in forum AutoCAD Beginners' Area
    Last Post: 4th Jan 2008, 10:25 pm
Tags for this Thread
