gporges Posted June 13, 2016 Share Posted June 13, 2016 I wrote a simple script that selects an object based off its coordinates. Layout set Layout1 Select 38.3989,2.7334,0 38.40124,1.03461,0 39.31814,1.4625,0 It works just fine when I simply copy the script and paste it into the command line. However when I run it as a script it asks me to specify opposite corner. A follow up question is after that I have copyclip: 39.31814,1.4625,0 copyclip Layout set layout2 pasteclip 37.80374,1.97425,0 However the dialog to select objects doesn't end. I have tried spaces and indents but it wont move on to copyclip. Any help would be greatly appreciated! Quote Link to comment Share on other sites More sharing options...
BIGAL Posted June 14, 2016 Share Posted June 14, 2016 You need to read up on W CP WP F window, crossing-polygon, within-polygon, fence, you have 3 xyz need only 2 Select W 38.3989,2.7334 38.40124,1.03461 Quote Link to comment Share on other sites More sharing options...
