Script to select objects only works as a Copy and Paste
I wrote a simple script that selects an object based off its coordinates.
Layout
set
Layout1
Select
38.3989,2.7334,0
38.40124,1.03461,0
39.31814,1.4625,0
It works just fine when I simply copy the script and paste it into the command line. However when I run it as a script it asks me to specify opposite corner.
A follow up question is after that I have copyclip:
39.31814,1.4625,0
copyclip
Layout
set
layout2
pasteclip
37.80374,1.97425,0
However the dialog to select objects doesn't end. I have tried spaces and indents but it wont move on to copyclip.
Any help would be greatly appreciated!
You need to read up on W CP WP F window, crossing-polygon, within-polygon, fence, you have 3 xyz need only 2
Select W 38.3989,2.7334 38.40124,1.03461
