Results 1 to 2 of 2
    Senior Member nscherneck's Avatar
    nscherneck's Computer Details
    Windows Vista 32b
    AutoCAD 2009
    Mar 2006
    Costa Mesa, CA
    135
    Default Text style problem
    Has anyone had trouble changing an MTEXT from one style to another in the properties table? I change the style but the text stays the same as before, the font doesnt change. I tried REGEN, but nothing, i close AutoCAD but the text remains as the old font. I restarted the computer, i though that would be a long shot, but still no change.
    Senior Member
    AutoCAD 2005
    Dec 2005
    Brandon, Manitoba, Canada
    166
    yes, I've en countered this brefore. Someone has used the mtext editor hightlighted the font they wanted to change and just changed it for the selected text, not the whole object. To change it's font now you will likely have to go into the mtext editor for that piece of text, and hightlight all you want to change, and change it in the font pull down, that would be the second pull down from the left in the mtext editor window.
    Hope this helps.
    Thalon
  1. Text Style
    By Frodraff in forum AutoCAD Drawing Management & Output
    Last Post: 27th Feb 2006, 06:24 pm
  2. Text Style
    By Jamalama in forum AutoCAD Drawing Management & Output
    Last Post: 29th Sep 2005, 08:11 pm
  3. Default Text Style in 2000LT
    By cadaholic in forum AutoCAD Beginners' Area
    Last Post: 22nd Aug 2005, 03:42 pm
  4. Purge A Text Style
    By jbaflyer in forum AutoCAD General
    Last Post: 3rd Aug 2005, 09:37 am
  5. Dimension>Style or Format>Dimension Style problem
    By jocaan in forum AutoCAD Beginners' Area
    Last Post: 21st Apr 2004, 08:50 pm
