iroctd Posted June 17, 2016 Share Posted June 17, 2016 Hi all, so if I create a simple box and then use offset edge from the solid menu it will work and I can enter a distance. If I make a cylinder and place it within the box, do boolean subtract to make a hole, then after that the offset edge does not work. Is there a way to get 'offset edge' working again? Do I need to fix the geometry/mesh since it has a hole in it? Thanks Quote Link to comment Share on other sites More sharing options...
ReMark Posted June 20, 2016 Share Posted June 20, 2016 That's just the way the command works. Quote Link to comment Share on other sites More sharing options...
