Results 1 to 9 of 9
Thread: Door distance
    Junior Member
    AutoCAD 2015
    Mar 2016
    18
    Default Door distance
    Hello all, I just have a general question. Im working on plate 1 of the electrical project, when I did the floor plan for the HVAC plates I just placed the doors where I was able to figure them out.
    My question is this, what is the distance recommended between the door on the hinge side and the corner of a wall? Is there a standard distance?
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,877
    This looks like it was taken from the Penn-Foster electrical project 8. Is that correct?
    Doesn't the sample drawing you are working off of have a dimension?
    I typically leave four inches. Most newbies tend to forget about the doorknob and leave 2" or less.
    Junior Member
    AutoCAD 2015
    Mar 2016
    18
    Hi yes this is from the electrical project. I was just trying to determine if there was a standard. The other floor plans I did I left 4" also. But no there is no dimension for the clearance between the door and the wall for the corners.
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,877
    Brutal truth. P-F doesn't care. As far as they are concerned they are teaching you how to use various AutoCAD commands. They are not teaching you how to be an architectural draftsman or designer. As long as they see the information they are looking for when your drawing is reviewed you shouldn't have any problems receiving a good grade.
  5. #5
    Junior Member
    AutoCAD 2015
    Mar 2016
    18
    ok thank you
  6. #6
    Forum Deity Dana W's Avatar
    Dana W's Computer Details
    Windows 8 64 bit
    Dell XPS ONE 2710
    Dunno
    Intel I-5 3330S @ 2.7 Ghz
    6 Gb
    On board barely adequate
    1 Terrabyte
    1 Terrabyte external
    All in one 27" touch & pen
    Construction
    Dana W's Discipline Details
    Architectural Millwork Designer/Draftsman
    Construction
    Custom commercial millwork.
    AutoCAD LT 2019
    Feb 2010
    Oviedo, Florida
    4,781
    Use 4 inches. The framing carpenters will do it the way the framing members actually fit amyway. And don't bother to dimension the distance either, if it is in the corner. If a door is more than 4" out of the corner, then dimension to the centerline of the door, and windows too.
    The S197 gen Ford Mustang, and the F-4 Phantom both prove the same theory. "With enough power applied, a school bus will fly."
  7. #7
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,877
    The purpose of this particular P-F project is not the construction of a house but the layout of fixtures, switches outlets and the wiring between them. The student, as I have seen from several drawings shared with me, could make the dimension 2", 3" or even 6" and the P-F instructor could care less. It's an electrical wiring plan not a framing plan.
  8. #8
    Windows 8 64 bit
    Dell XPS ONE 2710
    Dunno
    6 Gb
    1 Terrabyte
    Construction
    Construction
    AutoCAD LT 2019
    Feb 2010
    Oviedo, Florida
    4,781
    Understood, but the student wants to know more about architectural plans apparently, so I gave the standard, which is intended to leave enough room for typical door casing around the opening at the corner. Now, the student is a tiny little bit better armed when the day comes that they are presented with real floor plans.
  9. #9
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,877
    Then I guess we are in agreement since I too recommended four inches.
  1. Door Dynamic Block; Door Panel Scale Changes
    By p01ak in forum AutoCAD Drawing Management & Output
    Last Post: 27th May 2013, 12:50 am
  2. Trying to select a door causes entire wall and door to be selected. Why?
    By JamFam in forum AutoCAD 3D Modelling & Rendering
    Last Post: 10th Jan 2013, 12:05 pm
  3. DI(Distance) is only giving me X and Y distances and not the overall distance
    By baz88 in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 24th Sep 2012, 02:01 pm
  4. REQ: Place points and cumulative distance (text) on polyline, every X distance
    By enthralled in forum AutoLISP, Visual LISP & DCL
    Last Post: 7th Mar 2012, 11:28 am
  5. distance in paperspace - command distance
    By flopo in forum AutoCAD General
    Last Post: 20th Jul 2011, 06:41 pm
