Page 1 of 2 1 2 LastLast
Results 1 to 10 of 15
    Forum Newbie
    Inventor 2016
    Jun 2016
    9
    Default Stickers on inclined face
    Hi everyone
    i'm having issues on applying a decal on an inclined surface using inventor
    here's a screenshot to let you understand my situation.
    Using the decal tool I cant select the surface on where i put the image (the selected one, to let you understand)
    Thank you for the help
    Super Member
    Inventor 2016
    Mar 2009
    Ohio
    518
    Whats wrong it with it? Showing just an image of an unconsumed sketch doesn't help.
    What error are you receiving? Are you getting an unexpected result? Does this work on a simplified model?
    Mark Flayler
    Application Engineer - Manufacturing Solutions Division
    Blog: http://blogs.rand.com/manufacturing/
    Partner Certified, Inventor Certified Expert
    Forum Newbie
    Inventor 2016
    Jun 2016
    9
    you're right, i'm sorry
    just updated the post with the details of the issue
    Super Member
    Inventor 2016
    Mar 2009
    Ohio
    518
    I assume you are in the assembly environment, you need to be in the part mode for the decal to work.
    Mark Flayler
  5. #5
    Forum Newbie
    Inventor 2016
    Jun 2016
    9
    no, it doesn't work even in the part mode :/
  6. #6
    Super Member
    Inventor 2016
    Mar 2009
    Ohio
    518
    Is the part proprietary? Can you attach it if not or produce a simple example that shows the issue.
    Also make sure all your Service Packs and Hotfixes are installed.
    Mark Flayler
  7. #7
    Forum Newbie
    Inventor 2016
    Jun 2016
    9
    i'm uploading a video to show the issue clearly. Can i put here the link?
  8. #8
    Super Member
    Inventor 2016
    Mar 2009
    Ohio
    518
    I see no reason why not.
    Mark Flayler
  9. #9
    Forum Newbie
    Inventor 2016
    Jun 2016
    9
    here it is
    as you can see there are a couple of faces that i'm not allowed to select for some reason when i'm using the decal comand
    https://drive.google.com/file/d/0B_c...ew?usp=sharing
  10. #10
    Super Member
    Inventor 2016
    Mar 2009
    Ohio
    518
    ok, i definitely see what you mean. What feature has built that face you are trying to attach to?
    What is your Inventor version? Service Packs and Hotfixes installed?
    Are you in the Part mode when you are doing this video?
    Mark Flayler
  1. drawing circles on an inclined surface
    By mirvakili in forum AutoCAD 3D Modelling & Rendering
    Last Post: 4th Jun 2014, 03:36 pm
  2. 3D and inclined objects
    By pm4698 in forum AutoCAD 3D Modelling & Rendering
    Last Post: 9th Feb 2012, 11:55 am
  3. Keyboard Stickers
    By Jack_O'neill in forum Tutorials & Tips'n'Tricks
    Last Post: 12th Nov 2010, 05:51 pm
  4. Difference between Extrude face, offset face and move face
    By anayal in forum AutoCAD Beginners' Area
    Last Post: 12th Oct 2007, 12:17 am
Tags for this Thread
