Page 2 of 2 FirstFirst 1 2
Results 11 to 15 of 15
  1. #11
    Forum Newbie
    Inventor 2016
    Jun 2016
    9
    the face i'm trying to use is created using the chamfer.
    I'm working on Inventor 2016 and everything is up to date.
    yes i'm in the part mode
  2. #12
    Super Member
    Inventor 2016
    Mar 2009
    Ohio
    518
    Works just find on my system. What is your Inventor build number?
    Go to About Autodesk Inventor from the little bubble in the upper right.
    Mark Flayler
    Application Engineer - Manufacturing Solutions Division
    Blog: http://blogs.rand.com/manufacturing/
    Partner Certified, Inventor Certified Expert
  3. #13
    Forum Newbie
    Inventor 2016
    Jun 2016
    9
    is build 138
  4. #14
    Super Member
    Inventor 2016
    Mar 2009
    Ohio
    518
    Then you are not up to date on your updates.
    Put the SP in and see if it helps. https://knowledge.autodesk.com/suppo...-2.html?v=2016
    Next time post Inventor version with build number up front instead of having to go back and forth.
    Mark Flayler
  5. #15
    Forum Newbie
    Inventor 2016
    Jun 2016
    9
    ok thank you, i'll try and see if it works after the update
  1. drawing circles on an inclined surface
    By mirvakili in forum AutoCAD 3D Modelling & Rendering
    Last Post: 4th Jun 2014, 03:36 pm
  2. 3D and inclined objects
    By pm4698 in forum AutoCAD 3D Modelling & Rendering
    Last Post: 9th Feb 2012, 11:55 am
  3. Keyboard Stickers
    By Jack_O'neill in forum Tutorials & Tips'n'Tricks
    Last Post: 12th Nov 2010, 05:51 pm
Tags for this Thread
