Results 1 to 9 of 9
Thread: Delete layers
    Junior Member
    Civil
    Zeek's Discipline Details
    Civil
    One short CAD class, some time playing around... Trying to get "good" with CAD now...
    AutoCAD 2017
    Apr 2016
    Northwest United States
    11
    Default Delete layers
    There are 2 layers on this sample that QuickSelect says have nothing on them... Yet I cannot delete them. I've WBlocked, purged, dlete from Layer Prop Manager... I have hundreds of these I'm working on! Overall a relative newbie in CAD, not really digging LISP right now... so please try to keep solutions fairly straight forward.
    Layers are:
    FX-SGNSYM
    Bick
    Thank you
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,721
    Format > Layer Tools > Layer Delete. You can type the names in or select an object on the layer you wish to delete.
    When you are finished deleting the two layers run the OVERKILL command followed by AUDIT (say "yes" to fixing any errors). Then Save.
    Done.
    Junior Member
    Civil
    Civil
    AutoCAD 2017
    Apr 2016
    11
    Ahh Haa! Thanks So much!
    AutoCAD 2013
    Nov 2011
    5,993
    Quote Originally Posted by Zeek View Post
    For those like US, who are illisperate, there is a wonderful tool available in the right click shortcut menu, called the ACTION RECORDER.
    Basically a keystroke recorder which will by emulation write a custom macro to copy what you want it to do, in this case on hundreds of drawings.
    The time spent kicking the tires, and taking it around the block would be a very worthwhile investment, as it really speeds up repetitive tasks like these, without the need to write any code.
  5. #5
    Junior Member
    Civil
    Civil
    AutoCAD 2017
    Apr 2016
    11
    Ooohhh- I'll have to give that a shot. One of the last DWGs started with 244 layers... about 80 are applicable and stay and about 120 have "block references" that are visible nowhere and wont allow purge to wipe them out. LAYDEL 120 times on one DWG gets old fast.
    Thanks so much.
  6. #6
    Senior Member MillerMG's Avatar
    MillerMG's Computer Details
    Windows 7
    OPTIPLEX 3020
    Intel(R) Core(TM) i5-4570 CPU @ 3.30GHz
    8.0 GB
    The two in front of me. Dude, I got Dell's
    Civil
    MillerMG's Discipline Details
    CADD Drafter
    Civil
    Civil 3D 2017
    May 2014
    Fredericksburg, VA
    439
    You can use LAYDEL, if there is something attached to the layer it will still delete it. Just type in LAYDEL then N for name. It will give you a dialog of all layers.
  7. #7
    Super Moderator
    rkmcswain's Computer Details
    Windows 7 Pro x64
    HP ZBook 17
    i7-4810MQ @ 2.80 GHZ
    16GB
    Nvidia Quadro K4100M
    256GB SSD
    1TB SATA
    (2) HP 23"
    Civil
    rkmcswain's Discipline Details
    Civil
    CAD Manager
    Civil 3D 2017
    Sep 2005
    Houston
    4,481
    You can also use Layer Merge to merge the offending layer onto layer 0.
    R.K. McSwain
    CAD Panacea | twitter
  8. #8
    Luminous Being RobDraw's Avatar
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,173
    Quote Originally Posted by rkmcswain View Post
    That does not get rid of the offending blocks. I would use Layer Merge to an unused layer and then LAYDEL that layer.
    Drafting is a breeze.
  9. #9
    Junior Member
    Civil
    Civil
    AutoCAD 2017
    Apr 2016
    11
    Yes, RobDraw... that is actually what I've stumbled across and begun doing. After a QS on the layer and getting no selections I attempt to delete the layer. If that fails I merge it to a newly created layer I have named "TO DELETE". When merging it also tells me the name of any blocks or block references affected. Once all is cleaned I can LAYDEL my TO DELETE and ... what was once 250 layers is down to under 100!
    Thanks so much for the advice and information everyone-
  1. Layers won't delete?
    By TiffF in forum AutoCAD General
    Last Post: 19th Jan 2011, 03:06 pm
  2. Layers won't delete
    By nowikovs12 in forum AutoCAD Beginners' Area
    Last Post: 27th Dec 2010, 07:24 pm
  3. Delete Layers
    By repelectric in forum MEP
    Last Post: 16th Jun 2010, 06:11 pm
  4. Delete layers that wont delete
    By seashell2day in forum AutoCAD General
    Last Post: 31st Mar 2009, 02:38 pm
  5. How do I delete Layers?
    By chee_dee in forum AutoCAD General
    Last Post: 7th Sep 2007, 02:43 pm
Tags for this Thread
