sean112 Posted July 8, 2016 Share Posted July 8, 2016 Hello, all I am a beginner trying to create a program that can help me to match text box from a fixed position to another text box. Here is part of my code: (command "matchprop" (ssget '(597.5 88.2)) (ssget "W" '(600 62) '(625 100))) (command) The region that I selected should be correct since the result sometimes works properly but sometimes not. The textbox is just a text, not mtext. The input value does not change the outcome. Thanks ahead to everyone that responses. Quote Link to comment Share on other sites More sharing options...
BKT Posted July 8, 2016 Share Posted July 8, 2016 I'm hoping someone will explain why "W" didn't work when I tried this, either. If I changed it to "_C" that seemed to work, though. Hmmm... Quote Link to comment Share on other sites More sharing options...
vanowm Posted July 8, 2016 Share Posted July 8, 2016 I'm hoping someone will explain why "W" didn't work when I tried this, either. If I changed it to "_C" that seemed to work, though. Hmmm... with "W" entire object must fit into the selection region, with "C" all objects that even partially fit into the selection region will be selected as well. Perhaps that's applies to your case also Only objects visible in the drawing area at the time of selection will be selected by this method. Consider temporarily zooming to the selection window before performing the selection, and then zoom previous to restore the original screen position. Quote Link to comment Share on other sites More sharing options...
BKT Posted July 8, 2016 Share Posted July 8, 2016 Man, I thought I had the window completely enclosing the texts, but must have been off. Works now. Thanks! Quote Link to comment Share on other sites More sharing options...
sean112 Posted July 8, 2016 Author Share Posted July 8, 2016 Man, I thought I had the window completely enclosing the texts, but must have been off. Works now. Thanks! I spent about 3 hours trying to figure out why the fence, window and box work. And I found out it's just because the reference is not visible on the screen. Quote Link to comment Share on other sites More sharing options...
sean112 Posted July 8, 2016 Author Share Posted July 8, 2016 with "W" entire object must fit into the selection region, with "C" all objects that even partially fit into the selection region will be selected as well. Perhaps that's applies to your casealso Thanks vanowm. The second quote really helped me. Do you by any chance know how to use "getstring" and let the user input with space? My version is 2014, and "/ntext" did not work for me. Really appreciated. Quote Link to comment Share on other sites More sharing options...
Dadgad Posted July 9, 2016 Share Posted July 9, 2016 I spent about 3 hours trying to figure out why the fence, window and box work. And I found out it's just because the reference is not visible on the screen. Hello sean112, welcome to CADTutor. If you are learning the fine art of writing your own lisps, you should know about http://www.lee-mac.com/boundingbox.html Thanks Lee! Lee's excellent site has a special FUNCTIONS section for folks like yourself, learning the ropes, in addition to a wealth of highly evolved and broad ranging productivity enhancing lisps. By studying Lee's codes, you can reverse engineer, and get the jump on the learning curve! I thought seeing this particular link might help you to explore new approaches to the task at hand, and that having an available library such as this would be a good tool. Quote Link to comment Share on other sites More sharing options...
sean112 Posted July 9, 2016 Author Share Posted July 9, 2016 Hello sean112, welcome to CADTutor. If you are learning the fine art of writing your own lisps, you should know about http://www.lee-mac.com/boundingbox.html Thanks Lee! Lee's excellent site has a special FUNCTIONS section for folks like yourself, learning the ropes, in addition to a wealth of highly evolved and broad ranging productivity enhancing lisps. By studying Lee's codes, you can reverse engineer, and get the jump on the learning curve! I thought seeing this particular link might help you to explore new approaches to the task at hand, and that having an available library such as this would be a good tool. Thanks Dadgad Quote Link to comment Share on other sites More sharing options...
tombu Posted July 9, 2016 Share Posted July 9, 2016 Thanks vanowm. The second quote really helped me. Do you by any chance know how to use "getstring" and let the user input with space? My version is 2014, and "/ntext" did not work for me. Really appreciated. Online help for getstring explains it with examples. http://help.autodesk.com/view/ACD/2017/ENU/?guid=GUID-B139EFBD-74B7-4276-B422-D2186F7D8D0A Quote Link to comment Share on other sites More sharing options...
sean112 Posted July 9, 2016 Author Share Posted July 9, 2016 Online help for getstring explains it with examples.http://help.autodesk.com/view/ACD/2017/ENU/?guid=GUID-B139EFBD-74B7-4276-B422-D2186F7D8D0A Thanks tombu, that works! Quote Link to comment Share on other sites More sharing options...
