broncos15 Posted July 20, 2016 Share Posted July 20, 2016 I was curious if there is any way to edit the drag and drop features for a .dwg from windows explorer. The current settings are that if you left-click and drag a .dwg, .dwt, or a .dws from windows explorer it inserts it, and if you right-click and drag it you have a menu pop-up that has options to Insert, Open, Xref, Create Hyperlink. Is there anyway to change these preferences? Ideally I would like to add a line that says open read only for the right-click and to have the left-click just open it. Is this possible? Quote Link to comment Share on other sites More sharing options...
broncos15 Posted July 20, 2016 Author Share Posted July 20, 2016 I should also say that I have LISP routines to open documents as read only that I could have the menu line reference. Quote Link to comment Share on other sites More sharing options...
rkent Posted July 20, 2016 Share Posted July 20, 2016 If you want to drag and drop to open a file you can left MB drag, then drop over the ribbon or command line (any where but the in-canvas editing area), this will open the drawing rather than insert it. Don't know about open read only. Quote Link to comment Share on other sites More sharing options...
iconeo Posted July 25, 2016 Share Posted July 25, 2016 http://forums.augi.com/showthread.php?36566-Open-Drawing-read-only-from-Explorer Sent from my SM-G920T using Tapatalk Quote Link to comment Share on other sites More sharing options...
