cat3appr Posted July 22, 2016 Share Posted July 22, 2016 hello I'm having quite an headache from this: I need to copy in paper space a dwg that I have in model space, but I don't succeed to get it in the right place. My scale is 1:2000 so I know that by copying from model space i have to scale down 0.5 in paper space. The 0,0 in paper space is the bottom left corner, but I don't succeed how to place exactly my block title from model space as it is, in the same position in paper space.... anyone has any idea? thanks! Quote Link to comment Share on other sites More sharing options...
Dadgad Posted July 22, 2016 Share Posted July 22, 2016 Lee Mac knows how to do that, like just about everything else, as evidenced by the awesome collection of lisps on his site. http://www.lee-mac.com/ms2ps.html thanks Lee! Quote Link to comment Share on other sites More sharing options...
cat3appr Posted July 22, 2016 Author Share Posted July 22, 2016 Lee Mac knows how to do that, like just about everything else, as evidenced by the awesome collection of lisps on his site. http://www.lee-mac.com/ms2ps.html thanks Lee! No Dadgad, that's not what I need, I can't use viewports, please read my post. i need to place the actual drawing into paperspace, in the same position, no viewports. any idea? thanks! Quote Link to comment Share on other sites More sharing options...
ReMark Posted July 22, 2016 Share Posted July 22, 2016 Have you not heard of the Change Space command? CHSPACE http://www.ellenfinkelstein.com/acadblog/move-objects-between-model-and-paper-space/ Quote Link to comment Share on other sites More sharing options...
cat3appr Posted July 22, 2016 Author Share Posted July 22, 2016 Have you not heard of the Change Space command? CHSPACE http://www.ellenfinkelstein.com/acadblog/move-objects-between-model-and-paper-space/ I tried it, I got the error ** Command not allowed in Model Tab ** ... i need to copy stuff from model to paper... and it doesn't work plus, it needs viewports, and I explained that I can't use viewports, i need to transfer the actual object... Quote Link to comment Share on other sites More sharing options...
ReMark Posted July 22, 2016 Share Posted July 22, 2016 I guess you didn't bother to click on the link I provided for an explanation on how to use the command. I ran a test of my own by starting a new drawing and inserting my company's title block and border in model space. Then I switched to my layout, invoked the CHSPACE command and this is the result... Command: CHSPACE Select objects: Specify opposite corner: 1 found Select objects: 1 object(s) changed from MODEL space to PAPER space. Objects were scaled by a factor of 0.303316443675869 to maintain visual appearance. Bottom line. The command does work if you use it correctly. BTW, you will need to have ONE viewport in the layout. Quote Link to comment Share on other sites More sharing options...
RobDraw Posted July 22, 2016 Share Posted July 22, 2016 You could use copy with base point and then insert it at (0,0). Why didn't you just move it to where you need it to be? You probably don't want it exactly at (0,0), depending on how set your page set-up. You could have used a viewport so you could have utilized CHSPACE and then just erase the viewport if it was no longer needed. Quote Link to comment Share on other sites More sharing options...
ReMark Posted July 22, 2016 Share Posted July 22, 2016 I ran a second test in which a title block and border inserted in model space was moved to Layout1 via copy/paste and it worked just fine. I think you are rushing things and not paying attention to what AutoCAD is asking/telling you at the command line. Haste makes waste. And I agree with RobDraw. The viewport created for use of the CHSPACE command can be erased after the command is successfully run. I forgot to mention that. Quote Link to comment Share on other sites More sharing options...
cat3appr Posted July 22, 2016 Author Share Posted July 22, 2016 either i don't understand how to use this CHSPACE, or it doesn't work in my situation. this is what i did: i created a viewport in paper, around the area in which there are the objects i want to transport from model to paper. then i wrote CHSPACE, i was asked to select the objects, and i could only select the view port, so i did. then, enter. i then went to model, erased everything, because i cant have anything there, and i was expecting to see the objects in the viewport in paper space.... but... everything got erased there too basically i need to transport a few texts and the hatch, see red arrows, from model to paper, exactly in that position, how does this work? Quote Link to comment Share on other sites More sharing options...
RobDraw Posted July 22, 2016 Share Posted July 22, 2016 Before starting the command, activate the viewport. Quote Link to comment Share on other sites More sharing options...
cat3appr Posted July 22, 2016 Author Share Posted July 22, 2016 Before starting the command, activate the viewport. activate? if i draw a viewport and it's already there and working, i assume it's already active ... and how do i activate? please guide me step by step Quote Link to comment Share on other sites More sharing options...
ReMark Posted July 22, 2016 Share Posted July 22, 2016 Before starting the command, activate the viewport. It actually says that in the link I provided. It pays to carefully read and follow the instructions. Quote Link to comment Share on other sites More sharing options...
RobDraw Posted July 22, 2016 Share Posted July 22, 2016 Double click inside the viewport to activate it. It sounds like you could use a class or two or some tutorials for basic AutoCAD. Quote Link to comment Share on other sites More sharing options...
cat3appr Posted July 22, 2016 Author Share Posted July 22, 2016 It actually says that in the link I provided. It pays to carefully read and follow the instructions. how do i activate a viewport.... do you mean that i have to select it with the mouse? this is what i did, i selected the viewport, then CHSPACE... doesn't work. Quote Link to comment Share on other sites More sharing options...
cat3appr Posted July 22, 2016 Author Share Posted July 22, 2016 ok apologies.... thanks to all, i got it now, my mistake Quote Link to comment Share on other sites More sharing options...
ReMark Posted July 22, 2016 Share Posted July 22, 2016 You seem to be having your fair share of problems. Think about calling your local AutoDesk reseller and inquiring as to if they offer basic and advanced AutoCAD classes, when the next classes are scheduled and the cost. Quote Link to comment Share on other sites More sharing options...
MillerMG Posted July 25, 2016 Share Posted July 25, 2016 Have you not heard of the Change Space command? CHSPACE http://www.ellenfinkelstein.com/acadblog/move-objects-between-model-and-paper-space/ I'm going to go ahead and show my support for this Quote Link to comment Share on other sites More sharing options...
