AJSmith Posted July 27, 2016 Share Posted July 27, 2016 (edited) i have created a block for a Bridge joint but need help to finish it the is a regin nosing each side of the joint that i have added streches to but there is a rubber insert between that i normaly have as a block that i scalein just the X axis can this be added to the dynamic block?BEJ.dwg Edited July 27, 2016 by AJSmith Quote Link to comment Share on other sites More sharing options...
iconeo Posted July 28, 2016 Share Posted July 28, 2016 dang, i'm stumped. let me think about this for a bit. Quote Link to comment Share on other sites More sharing options...
iconeo Posted July 28, 2016 Share Posted July 28, 2016 BEJ.dwg It is not pretty. Not sure if there is a better way though. Quote Link to comment Share on other sites More sharing options...
AJSmith Posted July 29, 2016 Author Share Posted July 29, 2016 mmm ok thats one way thank you i thought it would be alot easyer lol Quote Link to comment Share on other sites More sharing options...
BIGAL Posted July 29, 2016 Share Posted July 29, 2016 If the rubber joint was a block just change X scale it does not change in Y direction, say metric draw it to 100mm then 120=1.2X etc simple properties change not dynamic block. Quote Link to comment Share on other sites More sharing options...
iconeo Posted August 1, 2016 Share Posted August 1, 2016 mmm ok thats one way thank you i thought it would be alot easyer lol Yeah me too. Unfortunately you can't use parameters in the XYZ block scaling properties. Quote Link to comment Share on other sites More sharing options...
