bennnn1980 Posted July 30, 2016 Share Posted July 30, 2016 Hello I'm knew to all this so if my question is too basic I apologise. I have what I believe is a 3d polyline of an object (boat). So when I open it, it looks like a series of cross sections of a hull with a few lines running the length of the hull. I would like to convert this to a solid object, and I was told inventor would be the program that would be the best to do this. I've now got a copy of inventor and am lost! So, could anyone advise me on how to convert this to a solid. Quote Link to comment Share on other sites More sharing options...
ReMark Posted July 31, 2016 Share Posted July 31, 2016 You have obviously posted to the wrong forum if indeed you are using Inventor and not AutoCAD. What program was used to create the drawing in the first place? Quote Link to comment Share on other sites More sharing options...
halam Posted July 31, 2016 Share Posted July 31, 2016 In AutoCAD this is done using the LOFT command. Choose the cross section in order and the path. Most likely in Inventor there is a similar command. All these great Autodesk program call it differently but the basics are very similar.. Just search for the right words.. Quote Link to comment Share on other sites More sharing options...
bennnn1980 Posted July 31, 2016 Author Share Posted July 31, 2016 The initial drawing was done in a program called DELTSHIP a few years back. Due to some computer issues, all I was left with was a .dxf (which is not suitable for what I need done). Anyway, I got a copy of AutoCAD as I thought that would be suitable. But I was then advised that I should try Inventor as its really good for 3D work. And that's what has landed me in this forum. So I'd take suggestions for both programs if they are available. I'll try the LOFT command now. Quote Link to comment Share on other sites More sharing options...
Dadgad Posted August 1, 2016 Share Posted August 1, 2016 (edited) Loft should be able to do it. The sections you describe, are most likely 2D Polylines, and one of the lines connecting them may serve as a PATH, when you want to loft them. Make a copy of your drawing, and experiment on that, and be sure to go slowly, and read the commandline carefully, as you will learn a great deal about the functionlity by doing so. Having just googled Loft command in Autocad, I just came up with a whole bunch, none of which I have watched, but this one is long enough, that it should help to get you back on the tracks, and to understand the uses and subtleties of the loft command. Edited August 1, 2016 by Dadgad Quote Link to comment Share on other sites More sharing options...
