+ Reply to Thread
Results 1 to 7 of 7
  1. #1
    Forum Newbie
    Using
    AutoCAD 2015
    Join Date
    Jun 2016
    Posts
    3
    Drawing Autolisp for partial distances(0.000.000), cumulative distance(0+000)pipeline profile
    HI THERE!
    AUTOLISP FOR CREATE A LISP FOR PL.dwgCopy of data from excel to acad.xlsxIN TEXT 90DEG ROTATED,
    NEED A AUTOLISP THAT CAN FUNCTION TO CREATE PARTIAL DISTANCES(0.000.000), CUMULATIVE DISTANCE(0+000.000) BASED ON THE LENGTH BETWEEN THE EACH VERTEX OF THE POLYLINE (APPROX. 3.69KM),
    PLEASE FIND THE ATTACHED DRAWING,
    THANKS IN ADVANCE
    PLEASE HELP,
  2. #2
    Luminous Being Dadgad's Avatar
    Using
    AutoCAD 2013
    Join Date
    Nov 2011
    Location
    At the confluence of worthlessness & invaluability
    Posts
    5,995
    Default
    Welcome to CADTutor nijil.
    Check out this lisp by Lee Mac
    http://www.lee-mac.com/chainlength.html
    Thanks Lee!
    Volume and repetition do not validate opinions forged in the absence of thought.
  3. #3
    Forum Newbie
    Using
    AutoCAD 2015
    Join Date
    Jun 2016
    Posts
    3
    Default
    Thank you, d
    that wasnt im looking for, although it can give the length,
    this lisp cant help to finish the work in time, can you go though to the attached files,
  4. #4
    Quantum Mechanic
    Using
    Civil 3D 2016
    Join Date
    Dec 2005
    Location
    GEELONG AUSTRALIA
    Posts
    10,159
    Default
    As the data is coming from excel its a simple pythagoras theory to work out the distance between pts and make a running total. There are lots of label pline vertices lisps out there also. Just add to the text line a Ch 1234.56 etc
    here is an example
  5. #5
    Using
    AutoCAD 2013
    Join Date
    Nov 2011
    Location
    Posts
    5,995
    Default
    Quote Originally Posted by nijil View Post
    Thank you, d
    nijil, sorry, but I beg to differ. While it may not do everything you need done, without your needing to lift a finger, it is certainly a giant step in the right direction.
    Meaning that it certainly CAN help to expedite the task at hand.
    The issue of finishing the work in time, which I understand is a real concern on your part, is affected by lots of variables, chronic offenders being the implementation of unrealistic deadlines, or lack of forethought.
    I encounter this all the time in my own work. Architects spend months longer than has been anticipated, to produce and sign off on geometry, for projects upon which we are working.
    No responsibility is taken for this, not adjustments made to the timeline, and the perception is that the next link in the chain is blessed with super natural powers, and burdened with the responsibility of retarding the passage of time, in order to complete their work, within the original time constraints of the project. In such cases, timelines have to be adjusted. We all hope to work quickly and efficiently, and aspire to best case timeline projections, but in the real world, there is no substitute for recognizing that, for what it is. It is always better to factor in extra time for changes, weather, bureaucratic delays, as students of history. By doing that, things tend to run more smoothly, and occasionally jobs can actually come in ahead of time, and under budget. As abnormal as that sounds, I have yet to hear anybody complain about it. The work is done better, because people are happier, more focused on what they should be, and relieved of all the unnecessary stress caused by doing it under the gun.
    Sorry, I don't mean to sound unsympathetic, I can relate to the pressures or unrealistic deadlines, as sadly they seem to be the norm, in so many projects.
    Unfortunately, I am illisperate, and so unable to help further than to direct folks who post on this forum, to lisp resources which I use and admire.
    First and foremost, that would be to Lee Mac's wonderful site. Thanks Lee!
    I will defer to BIGAL on this one, as he has lots of experience in this field, unlike myself, and is lisperate.
    I hope that he or one of the other forum members has something more to help you get it in, under the wire.
  6. #6
    Forum Newbie
    Using
    AutoCAD 2015
    Join Date
    Jun 2016
    Posts
    3
    Default
    hi friends, thank you for your prompt replies,
    i have still hope in you, that someone can sort this out, all the data i have made it (attached) from none,
    that is the text format i have to change in it - partial distances(0.000.000), cumulative distance(0+000)pipeline profile!
  7. #7
    Quantum Mechanic
    Using
    Civil 3D 2016
    Join Date
    Dec 2005
    Location
    GEELONG AUSTRALIA
    Posts
    10,159
    Default
    have a look at my prior post there is lots of chainage lable out there.
Similar Threads
  1. Cumulative distance at intersection
    By souvik in forum AutoLISP, Visual LISP & DCL
    Last Post: 2nd Nov 2014, 11:42 am
  2. Pipeline route profile (graph)
    By kevin_900922 in forum AutoCAD General
    Last Post: 16th May 2012, 04:03 am
  3. REQ: Place points and cumulative distance (text) on polyline, every X distance
    By enthralled in forum AutoLISP, Visual LISP & DCL
    Last Post: 7th Mar 2012, 11:28 am
  4. Pipeline Longitudinal Profile
    By viriato79 in forum Autodesk Software General
    Last Post: 25th Apr 2011, 12:21 pm
  5. Cumulative distance in attribute
    By sakinen in forum AutoLISP, Visual LISP & DCL
    Last Post: 23rd Jul 2009, 06:19 pm
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
