Results 1 to 2 of 2
    Full Member grouch19's Avatar
    Map 3D 2012
    Mar 2008
    76
    Default Random vertices shift
    Hi guys,
    Bit of a strange request.
    I'm looking for something that will shift a selection of polygon vertices by a random amount for each vertex. In a perfect world I'd love to set a tolerance of say 5cm and have the vertices move in any x,y direction by random amounts up to 5cm.
    Any ideas would be appreciated.
    Cheers
    Dave
    If it aint broken don't touch it
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,587
    Simple lee-mac random number generator, this will give a line length, a 2nd go the angle then polar from a point and move the vertice. I have used this to generate tree leaves, there was also a add a random circle which I used it for also, I think its on my work pc.
    Found
    http://www.cadtutor.net/forum/showth...ghlight=Random
  1. Random elevations
    By CL Seals in forum AutoCAD General
    Last Post: 10th Jan 2014, 12:16 pm
  2. random pc3 file changing to random plotter
    By halfcracked in forum AutoCAD Bugs, Error Messages & Quirks
    Last Post: 27th Mar 2013, 11:02 pm
Tags for this Thread
