Results 1 to 6 of 6
    Senior Member
    Manufacture
    BrianTFC's Discipline Details
    Structral Detailer
    Manufacture
    AutoCAD 2017
    Jan 2012
    Indiana
    188
    Default Plot to PDF and Combine into one file
    All,
    I need some help with this PDF plot lisp that was created at work, this lisp was created to take material list sheets PDF them and drop them into the source folder with the sheet name as the file name. I was wondering if someone could help figure out how to combine the pages together to create one file once they are converted to PDF all as one step.
    Code:
    ;;;This is the lisp routine to Plot the material list to individual PDF files with the job name and the page number
    ;;;as is does in the Plot Material List button.
    ;;; plotpdf.lsp
    (defun c:PlotPDF (/ ob ss bn mn mx)
          (vl-load-com)
        (setq cnt 0)
        (setq dir(getvar "dwgprefix"))
                (if (and (progn
                     (initget "B")
               (setq ob (entsel "\nSelect Block/B for blockname: "))
                    (cond
                    ((eq ob "B")
                        (setq bn (getstring "\nEtner Block Name: "))
                    ((and (eq (type ob) 'LIST)
                   (vlax-method-applicable-p (vlax-ename->vla-object (car ob)) 'getboundingbox))
                          (setq bn (cdr (assoc 2 (entget (car ob))))))))
      (tblsearch "BLOCK" bn)
                    bn
                    (setq ss  (ssget "_X" (list '(0 . "INSERT")'(410 . "Model")(cons 2 bn))))
              (vla-zoomextents (vlax-get-acad-object))
      (setq ML "Material-List")
      (setq cnt (1+ cnt))
      (vla-getboundingbox (vlax-ename->vla-object (ssname ss (setq i (1- i)))) 'mn'mx)
          (command "plot" "yes" "model" "DWG To PDF.pc3" "ANSI A (8.50 x 11.00 Inches)"
              "inches" "LANDSCAPE" "no" "Window"
              (trans (vlax-safearray->list mn) 0 1)
              (trans (vlax-safearray->list mx) 0 1)
              "fit" "center" "yes" "acad.ctb"  "yes" "As Displayed" (strcat dir "ML-" (itoa cnt) "-"(getvar "dwgname")) "no" "yes" "yes" "yes")
                    (command ".delay" "750")
                   (princ "\nNo Blocks Selected: ")
              )(princ)
    Thanks,
    Brian
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,587
    Adobe acrobat thats what we have access to it has COMBINE as a option. Takes maybe 2 minutes or less to make 1 pdf with all in. 88 sheets = 15Mb.
    There are posts about PDF's creators Bluebeam etc which appear to have this ability, I am sure others will post
    Senior Member
    Manufacture
    Structral Detailer
    Manufacture
    AutoCAD 2017
    Jan 2012
    Indiana
    188
    thanks for the reply BIGAL, I guess the big question is..can it be done thru lisp? if AutoCAD isn't capable of combining them that's fine just let me know...
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,587
    Theres is posts about using Publish and making 1 pdf pretty sure you have to have the right pdf creator I dont think Dwg to pdf works.
  5. #5
    Super Member
    not applicable
    Jun 2016
    673
    Ghostscript can be used to combine PDFs.
    Something like this should work:
    Code:
    (defun KGA_String_Join (strLst delim)
      (if strLst
        (apply
          'strcat
          (cons
            (car strLst)
            (mapcar '(lambda (a) (strcat delim a)) (cdr strLst))
    ; (CombinePdf
    ;   "C:\\Program Files\\gs\\gs8.61\\bin\\gswin32c.exe"
    ;   '("D:\\Tmp\\A.pdf" "D:\\Tmp\\B.pdf")
    ;   "D:\\Tmp\\Total.pdf"
    ; Note: Existing trgFile will be overwritten.
    (defun CombinePdf (gsExe srcFileLst trgFile)
      (startapp
        (strcat
          gsExe " "
          "-dBATCH -dNOPAUSE -dQUIET -sDEVICE=pdfwrite "
          "-sOutputFile=\"" trgFile "\" "
          "\"" (KGA_String_Join srcFileLst "\" \"") "\""
    BricsCAD 18
  6. #6
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,587
    Nice idea Roy_043 will have a play the srcfilelst can be made pretty easy as as you plot each pdf you add it to the list. and then run as per your code.
    in the code above
    Code:
    (setq pdfname (strcat dir "ML-" (itoa cnt) "-"(getvar "dwgname")))
    (setq srcfilelst (cons pdfname scrfilelst))
    Seems to work pretty good may do it for say more than 4 pdf's will have a chat with the guys and gal.
  1. Many Lisp files combine in one Lisp file...
    By CAD USER in forum AutoLISP, Visual LISP & DCL
    Last Post: 1st Dec 2015, 03:37 am
  2. Changes to plot layout and plot file for publish
    By GliderRider in forum AutoCAD Drawing Management & Output
    Last Post: 12th Mar 2009, 09:48 pm
  3. Plot To File
    By Brunello19 in forum AutoCAD Drawing Management & Output
    Last Post: 14th Jul 2006, 02:47 pm
  4. plot to file (as a batch file)
    By tbui63 in forum AutoCAD General
    Last Post: 26th Apr 2006, 07:30 pm
  5. plot file locations for batch plot?
    By Kate M in forum AutoCAD General
    Last Post: 29th Oct 2003, 09:43 pm
Tags for this Thread
