Results 1 to 9 of 9
    Junior Member
    tmd_63's Computer Details
    Windows 7
    12Gb
    Electrical
    tmd_63's Discipline Details
    Electrical
    I use AutoCAD to create PWB outlines and also for the enclosures for use with PWB's. I have both AutoCAD Mechanical 2016 and the Vanilla revisions.
    AutoCAD 2016
    Jul 2016
    UK
    22
    Question How to 3d fillet to a point
    I have a cube that I need to fillet but the fillets must merge.
    the left to centre edge/fillet is a constant curve. the same with the bottom to centre edge/fillet. but the edge from centre to the right starts at a radius and goes into a point at the corner.
    What command or sequence of commands can create this? Note, the point where the 3 fillets meet must all curve gently.
    Super Member Patrick Hughes's Avatar
    Patrick Hughes's Computer Details
    Win 7 x64
    Dell Precision T7610
    Intel Xeon E5-2630 v2 (six core)
    32 Gb
    3 Gb Nvidia Quadro K4000
    1 TB
    2x 1920x1080 Dell Ultrasharp U2312HM
    Mechanical
    Patrick Hughes's Discipline Details
    Self unemployed - Machine Design
    Mechanical
    Machine Design
    AutoCAD 2015
    May 2008
    Rockford, Illinois
    763
    Consider creating a cone with a base radius equal to the full fillet radius and a height equal to the leg length minus the radius, union a sphere with at the base with radius equal to the fillet.
    Now use this to "drill" into another solid that has had your original box subtracted from. Now you've got a solid that you can subtract from your cube.
    www.cadtempo.com
    Time tracking for AutoCAD, Inventor, Revit and other CAD programs
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,878
    My feeble attempt yielded this result. Best I can do at the moment.
    I used a different method than what is described in the above post.
    I'd give it another try but I'm working today in an office where the AC unit died and it feels like I'm cadding in a rain forest. LOL
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,878
    tmd_63: Did you ever solve your problem? If so, what method did you use?
  5. #5
    Junior Member
    Windows 7
    12Gb
    Electrical
    Electrical
    AutoCAD 2016
    Jul 2016
    UK
    22
    ReMark,
    Your picture looks perfect. How did you create that?
    I have been trying but I keep getting plane face errors. I want to use this method to make a fillet from 3 joining 3d walls.
    The 3d walls have one wall which is a wedge shape and therefore needs to have the fillet changing from a 3mm in the corner to zero where the fillet meets the floor. SO my idea was to use this shape and 3d subtract from a 3d block to make the fillets.
    I have not been having much luck with the revolve of the cone because the cone is not aligned to the normal XYZ axis. I dont have inventor to be able to quickly a variable fillet and I am seriously thinking of using Blender instead to create the shape I need instead of AutoCAD.
  6. #6
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,878
    Here is a depiction of the sequence I followed. I initially divided the 3D model into two parts. The front part was relatively simple as it only required the use of the fillet command. As for the back part the method I used basically relied on lofting one-quarter of a circle (at front corner) and a very, very small right angle (at the rear corner) to create a surface used to slice the edge of the box off. Understand?
    2Dwireframe visual style. Isometric view.
  7. #7
    Luminous Being tzframpton's Avatar
    tzframpton's Computer Details
    HP Zbook
    Multi-disciplinary
    tzframpton's Discipline Details
    BIM Specialist
    Multi-disciplinary
    Full Virtual Design and Construction BIM services for the MEP engineering and construction industries.
    Revit 2019
    Mar 2006
    Dallas, TX - USA
    9,140
    Use the FILLETEDGE command. It's specific to 3D, while FILLET does work, but is more specific to 2D. With FILLETEDGE, you can select multiple edges before you complete the command, as well as having Chain and Loop options. Just make sure your radius is logically possible and it'll work, especially on simple geometry like a box. Trying it on complex geometry, say, a guitar body, will make you pull your hair out. Trust me I know.
    -TZ
    *EDIT*
    Demonstration video attached:
    http://screencast.com/t/T8QY4I0UY3
    Tannar Z. Frampton ™ | Frampton & Associates, Inc.
  8. #8
    Junior Member
    Windows 7
    12Gb
    Electrical
    Electrical
    AutoCAD 2016
    Jul 2016
    UK
    22
    Hi Tannar,
    Great video, but this does not complete the action required. One of the edges goes from a 3mm fillet at the rounded corner to a 0mm fillet at the other end. Basically it is a variable fillet that changes radii from one end to the other. It looks like a cone has been placed along the edge as ReMark has shown.
    Hi ReMark,
    I am still unclear as to how the lofting of the quarter circle worked?? What does the very very small right angle do?
    You create an arc that is the same as the quarter circle, type loft, select the arc..... then what did you do? This is where I get lost.
    Regards
  9. #9
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,878
    I did a loft between the quarter circle and the small right angle and used the resultant surface that was created to slice off the squared corner of the box. Very simple...very direct.
    Someone here can possibly demo the technique and post a drawing. Unfortunately I can't do that at the moment from 30,000 feet in the air. My arms aren't long enough.
  1. Dline, Break, Fillet, ............................ Break, Fillet,
    By hkncdrc in forum AutoLISP, Visual LISP & DCL
    Last Post: 11th Sep 2015, 07:53 am
  2. Replies: 7
    Last Post: 23rd Jul 2014, 01:08 pm
  3. concave fillet:how to do using fillet cmd?
    By stenews in forum AutoCAD General
    Last Post: 12th Feb 2012, 03:52 pm
  4. Replies: 1
    Last Post: 29th Aug 2011, 10:00 pm
  5. Replies: 0
    Last Post: 29th Aug 2011, 09:52 pm
Tags for this Thread
