Volume3k Posted August 14, 2016 Share Posted August 14, 2016 Hi everyone. I'm having a problem joining a knit solid surface that I created by merging surfaces together, into a solid loft. I want to do this because I have a pattern cut out and when I array the pattern, it will not cut into the knit side on the right. http://imgur.com/a/2PNBa Does anyone know a way around this? Quote Link to comment Share on other sites More sharing options...
shift1313 Posted August 15, 2016 Share Posted August 15, 2016 How many solid bodies are there? Maybe that section isnt combined with the rest. Look at the feature tree. Do you see a folder at the top called "solids"? Quote Link to comment Share on other sites More sharing options...
Volume3k Posted August 15, 2016 Author Share Posted August 15, 2016 after looking at it again it seems that my surfaces aren't a solid body from knitting. When I try to knit them together to make a solid I get this message http://imgur.com/KO9lznU Any ideas how to fix this? Quote Link to comment Share on other sites More sharing options...
shift1313 Posted August 15, 2016 Share Posted August 15, 2016 You either have 2 or more that aren't touching or maybe are exact copies. Try knitting a few at a time. If it works try editing and adding a few more. Looks like you have a ton of little pieces. Quote Link to comment Share on other sites More sharing options...
