Results 1 to 2 of 2
    Full Member
    AutoCAD 2017
    Mar 2013
    25
    Default Create Custom View of Equipment with Tags
    AutoCAD P&ID 2015 Help.
    Would like to know if a custom view can be created for the Data Manager that includes a column for TAGS.
    Currently created a view of Skids with Level 1 as Engineering Items.SKID.
    However there is no column for TAGS. Can one be added somehow?
    Full Member
    Jach's Computer Details
    I got 2 screens yeah!
    P&ID 2014
    Feb 2012
    Planet Earth
    36
    I have done it in AutoCAD P&ID 2014, so should not be a problem.
    Under project setup, there should be something called Reports, in there you can modify or create some new Defined Reports.
    When you have defined what you want on your report in the data manager, you will be able to find the Report in Project Reports inside the Data Manager (look for the dropdown menu on the top left of the data manager)
  1. Creating Custom Tags That Group Identical Doors/Windows
    By MaxwellEdison in forum Architecture & ADT
    Last Post: 1st Jul 2016, 02:54 pm
  2. Custom Door tags in Revit 2009
    By AHL808 in forum Revit General
    Last Post: 19th Feb 2009, 09:50 pm
  3. Plz help tryin2 view equipment in MEP2008
    By ChrisRose in forum AutoCAD Drawing Management & Output
    Last Post: 11th Sep 2007, 02:09 pm
  4. ADT 3.3 Custom Schedule Tags
    By Galingula in forum AutoCAD Drawing Management & Output
    Last Post: 18th Sep 2006, 05:27 pm
  5. custom tags linked to schedules ADT 2006
    By stormtrooper in forum AutoCAD General
    Last Post: 10th Mar 2006, 08:38 pm
