nowikovs12 Posted August 16, 2016 Share Posted August 16, 2016 Hi guys, Using Autocad LT 2016 Mac. Normally when drawing rectangle you get live box next to it showing how big it is as you are drawing it. On my version of autocad when I draw the rectangle I don't get any live info that is very annoying. Normally I will draw rec and use it as a measure tool and finally confirm the distance. See image attached. I tried all dynmode versions from -3 to 3 no luck. Quote Link to comment Share on other sites More sharing options...
rkent Posted August 16, 2016 Share Posted August 16, 2016 Try setting DYNPIVIS to 1 or 2. From command line, or dyn input settings. Quote Link to comment Share on other sites More sharing options...
nowikovs12 Posted August 17, 2016 Author Share Posted August 17, 2016 Thanks rkent! Setting DYNPIVIS to 1 did the job. Quote Link to comment Share on other sites More sharing options...
