Linetype Generation
Where would (if there is a way) I change the default setting for linetype generation? Whenever I draw a polyline the setting is set to disabled. I would like for it to be enabled instead. Any help is always appreciated.
Regards,
Miller
As per Lee Mac's tutorial re: loading programs automatically in AutoCAD.
Upon opening a drawing or starting a new drawing, AutoCAD will search all listed support paths including the working directory for a file with the filename: ACADDOC.lsp. If one or more such files are found, AutoCAD will proceed to load the first file found.
With this knowledge one can edit or create an ACADDOC.lsp to include any AutoLISP expressions to be evaluated upon startup.
One clear advantage to using the ACADDOC.lsp to automatically load programs is that, upon migration, it may easily be copied from computer to computer, or indeed reside on a network to load programs on many computers simultaneously.
You can create your own ACADDOC.lsp in Notepad.
