Results 1 to 8 of 8
    Forum Newbie
    AutoCAD 2013
    Aug 2016
    2
    Default Problem with Autocad 2013 page setup
    Hi all, I am having issues with what I believe could be a corrupted page setup file. I have gone to the page setup manager to try and delete and re-create, but ANY interaction with the page setup in question causes CAD to immediately lock up and crash (even a right click, somehow). Does anyone know the folder location of these files so that i can go in and manually get rid of one? Thanks
    Edit: I am using a windows 7 machine.
    Senior Member TheCADnoob's Avatar
    See details...
    TheCADnoob's Discipline Details
    Drafter
    See details below.
    Got a degree in rocket surgery that I cant use so I'm doing CAD work. I literally have my hands on all disciplines and am loving every minute of it, unfortunately by not specializing I believe I have found the Zen Noob. Jack of all master of none.
    AutoCAD 2013
    Mar 2015
    246
    Have you tried running the program as administrator?
    IT - "I would be glad to help you, but first I need you to make sure you computer is plugged in."
    CADnoob - "I'm Not that dumb"
    IT - "I'm sure you are not, but could you just humor me?"
    CADnoob - "Ok Ok... let see.. Crap! Never mind, thanks for your help."
    Forum Newbie
    AutoCAD 2013
    Aug 2016
    2
    Yep, same issue.
    See details...
    Drafter
    See details below.
    AutoCAD 2013
    Mar 2015
    246
    is it just this file?
    Have you tried running an audit?
  5. #5
    Luminous Being RobDraw's Avatar
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,179
    I'm not sure there is a folder. They are stored in the drawing file.
    Drafting is a breeze.
  6. #6
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,126
    Do you have all of the service packs hotfixes, and updates for AutoCAD 2013 installed?
  7. #7
    Super Moderator rkmcswain's Avatar
    rkmcswain's Computer Details
    Windows 10
    HP Z240
    i7-7700k @ 4.20GHz
    64GB
    Nvidia Quadro P1000
    0.5TB SSD
    1TB SATA
    Vizio 40"
    Civil
    Civil 3D 2019
    Sep 2005
    Houston
    4,593
    Are you saying that you can get to this screen, but if you select the page setup and click Modify, that is when it crashes?
    R.K. McSwain
    CAD Panacea | twitter
  8. #8
    Forum Deity rkent's Avatar
    rkent's Computer Details
    WIN7 PRO 64bit
    Dell OptiPlex 7020
    i7 4790 3.6GHz
    16GB, 1600MHz, DDR3 non-ECC 2x8GB
    AMD Radeon 2GB
    Samsung 480Gb SSD
    Dell 24" FS (2x)
    Mechanical
    rkent's Discipline Details
    Mechanical
    Mechanical 2017
    Nov 2007
    4,598
    This lisp is supposed to delete those for you. Page setups are kept in the drawing.
    Code:
    ;;; save this file to a folder on your C:\ drive, name it PAGESETUP.LSP or any name you want
    ;;; use the AppLoad command, navigate to this file so it will load each time
    ;;; type DELETEALLPS to delete all page setups in the drawing or set up a button
    ;;; type PAGESETUP_IMPORT to import all page setups in the drawing or set up a button
    ;;;Dave Jones
    ;;;Member of the Autodesk Discussion Forum Moderator Program
    ;Command: (deleteAllPS)
    ;or
    ;Command: (deletePS "PageSetupName")
    (defun c:DELETEALLPS ()
      (vl-load-com)
      (vlax-for ps (vla-get-plotconfigurations
                   (vla-get-activedocument
                   (vlax-get-acad-object)))
      (vla-delete ps)
    (defun deletePS (name)
      (vl-load-com)
        (if (= (strcase (vla-get-name ps)) (strcase name))
        (vla-delete ps)
    ;;import page setups - not sure of the original source for this code below
    (defun C:PAGESETUP_IMPORT (/ exprt)
    (setq exprt (getvar "EXPERT"))
    (setvar "EXPERT" 2)
    ;;;CUSTOMIZE THE LINE BELOW THIS ONE FOR YOUR PATH AND DRAWING OR TEMPLATE WITH YOUR PAGESETUPS, see below
    (command "._-PSETUPIN" "C:\\YOURPAGESETUPS.dwg" "*")  ;change the name and path to your dwt file, etc
    (setvar "expert" exprt)
    ;your pagesetup path will resemble the one below, type that in the line above for YOURPAGESETUPS.DWG
    ;"C:\\Users\\USERNAME\\AppData\\Local\\Autodesk\\AutoCAD Mechanical 2015\\R20.0\\enu\Template\\template.dwt"
    Sometimes there's a man... I won't say a hero, 'cause, what's a hero? But sometimes, there's a man. And I'm talkin' about the Dude here. Sometimes, there's a man, well, he's the man for his time and place. He fits right in there. And that's the Dude, in Los Angeles. - The Stranger, The Big Lebowski
  1. Autocad 2013 page setup/ plot styles
    By arcbc30 in forum AutoCAD Drawing Management & Output
    Last Post: 4th Mar 2014, 02:28 pm
  2. Page Setup Manager is crashing Autocad 2010
    By laylarosales in forum AutoCAD Bugs, Error Messages & Quirks
    Last Post: 21st Mar 2013, 11:43 pm
  3. Page setup manager problem ! Help please!
    By J_xtreme in forum AutoCAD Drawing Management & Output
    Last Post: 24th Jan 2013, 02:08 pm
  4. Problem with plot scale in page setup
    By MorgaineDax in forum AutoCAD Drawing Management & Output
    Last Post: 29th Jun 2011, 02:53 pm
  5. Page Setup Resets To Portrait from Landscape in Sheet Set Page Setup Overrides DWT
    By Kapanther in forum AutoCAD Drawing Management & Output
    Last Post: 30th Nov 2010, 12:31 am
Tags for this Thread
