Page 2 of 2 FirstFirst 1 2
Results 11 to 18 of 18
  1. #11
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,623
    After having my usual ten cups of coffee and looking at this again with fresh eyes I think the 3D model of the roof could be constructed using just the LOFT command. Once I have ACAD up and running I might give it a try.
  2. #12
    Senior Member
    danellis's Computer Details
    Windows 7
    Dell Precision T1650
    Architecture 2014
    Dec 2010
    308
    If you're still looking for an ACA-based solution, I'd do it by producing two roofs - one for the main building and a second for the bay window.
    dJE
  3. #13
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,623
    Got that chance to try it again. Lofting a couple of similar triangles then joining them with the union command does work.
  4. #14
    Full Member
    tom111's Computer Details
    Windows 7 Enterprise
    8.00 GB
    Architecture 2015
    Oct 2013
    UK
    33
    Thanks ReMark, would you perhaps be able to share a file of that so I can examine and tweak?
    Thanks danellis,unfortunately I don't have the smarts to achieve this by using two roofs although this is something I tried originally. I had issues per the below sketches when I did this however:
  5. #15
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,623
    It's just two different size triangles lofted. It doesn't get any easier than that.
  6. #16
    Luminous Being tzframpton's Avatar
    tzframpton's Computer Details
    HP Zbook
    Multi-disciplinary
    tzframpton's Discipline Details
    BIM Specialist
    Multi-disciplinary
    Full Virtual Design and Construction BIM services for the MEP engineering and construction industries.
    Revit 2018
    Mar 2006
    Dallas, TX - USA
    9,068
    Side topic: Is AutoCAD Architecture the only program you have access to? Usually, ACA comes as a suite that includes Revit, and these types of things are far simpler in Revit rather than AutoCAD Architecture. I know this doesn't solve the immediate issue at hand, but it's worth looking into if this is common work you frequently perform.
    -TZ
    Tannar Z. Frampton ™ | Frampton & Associates, Inc.
  7. #17
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,623
    As per your request. See attached. It is pretty self-explanatory. Saved in AutoCAD 2010 file format so you should have no trouble opening it.
    ACA roof design.dwg
  8. #18
    Full Member
    8.00 GB
    Architecture 2015
    Oct 2013
    UK
    33
    Thank you
  1. trim rectangle outside object
    By sanju2323 in forum AutoLISP, Visual LISP & DCL
    Last Post: 11th Jun 2015, 08:38 pm
  2. Trim a roof
    By zionshea in forum Architecture & ADT
    Last Post: 23rd Oct 2014, 07:47 pm
  3. slice a radius 3d object
    By dreamer in forum AutoCAD 3D Modelling & Rendering
    Last Post: 2nd Jun 2014, 11:46 am
  4. Slice/trim? Solid or surface?
    By byk3bep in forum AutoCAD 3D Modelling & Rendering
    Last Post: 12th Jun 2013, 11:19 am
  5. How to trim a Loft object?
    Last Post: 10th Jul 2010, 03:55 pm
