Contour line to elevation
blackmember
Are you asking about labeling each contour line with its perceived elevation?
Yep! Is there a way I can do it in AutoCAD or do I need Civil? I downloaded Civil just in case.
There is no command native to AutoCAD that could do it although there could be a custom lisp routine that is capable. I don't know as I don't work with contour maps in my line of work. A search would be required.
The post above is a good idea a simple lisp would get the z value and write as text.
(while (setq obj(vlax-ename->vla-object (car (entsel "\nPick contour nothing to exit"))))
(setq z (vla-get-elevation obj))
(command "Text" (getpoint) 1 0 (rtos z 2 3)) ; note text style height = 0
;(command "Text" (getpoint) 1  (rtos z 2 3)) ; note text style height is set
  • 2 weeks later...
where are you located with elevations like that? In my area the highest usually is around the 500s. I assume you would like to avoid clicking each polyline and inputting the elevation into the properties?
