Results 1 to 2 of 2
    Full Member
    not specified
    Jul 2006
    London UK
    55
    Default Xref Unselectable?
    How do i make an xref unselectable on the screen so im not selecting it by accident? (AC2007)
    Senior Member Groutie's Avatar
    Groutie's Computer Details
    i7 3.6 GHz
    32Gb
    Quadro 4000 2Gb
    AutoCAD 2013
    Jun 2006
    London
    127
    If you go to the layer dialogue box you'll see a little padlock by the side of each layer (along with on/off, freeze/thaw etc). If you change your XREF onto a new layer say 'XREF1' then click the padlock shut for 'XREF1' then you'll not be able to select the XREF(s) on that layer, easy. Note, all locked layers will highlight when selected, but you'll not be able to edit/move them etc. Trust that's what you wanted
  1. UPDATE xREF
    By gortex in forum AutoCAD General
    Last Post: 17th Apr 2006, 03:51 pm
  2. XREF NEEDS RELOADING
    By THE JACK in forum AutoCAD Drawing Management & Output
    Last Post: 10th Apr 2006, 03:29 pm
  3. Layer states don't transfer from an Xref of an Xref....
    By Dave-CSMW in forum AutoCAD Drawing Management & Output
    Last Post: 28th Feb 2006, 06:02 pm
  4. Xref problem
    By tech46 in forum AutoCAD Beginners' Area
    Last Post: 28th Jan 2006, 07:43 pm
  5. Xref
    By ebjco in forum AutoCAD Drawing Management & Output
    Last Post: 3rd Jan 2006, 03:12 pm
