coordinates display next to crosshair
Are you referring to Dynamic Input (DYNMODE)?
no, i know about dynamic input.
i'm talking about crosshair showing coordinates when you move it without having any command active.
Then you are referring to the Drafting Settings > Dynamic Input > Enable Pointer Input > Settings button > Pointer Input Settings window > Visibility > Always - even when not in command. However, DYNMODE must be on for the coordinates to show up on your screen.
[ATTACH]59148[/ATTACH]
thanx for the reply it helped. i changed DYNPIVIS to 2 & it worked.
