MTE20112 Posted September 3, 2016 Share Posted September 3, 2016 I have created new blocks with many different attributes that I am hoping to use in my older drawings. I want to replace the old blocks, but sometimes they do not have the same insertion point and when I replace them all the blocks move. Rather than having to edit all of these blocks and match the insertion point is there ANY way to replace/redefine the old blocks without moving them? Thank you Quote Link to comment Share on other sites More sharing options...
RobDraw Posted September 3, 2016 Share Posted September 3, 2016 You will need as many versions as there are different insertion points. Quote Link to comment Share on other sites More sharing options...
Spaj Posted September 3, 2016 Share Posted September 3, 2016 Experiment with Lee Mac's ChangeBasePoint routine. You may get lucky. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted September 3, 2016 Share Posted September 3, 2016 I agree with Robdraw the blocks must match, but a quick and dirty use Filter pick the block remove the co-ord's etc so it picks all of them. MOVE P 0,0 newx,newy Quote Link to comment Share on other sites More sharing options...
MTE20112 Posted September 5, 2016 Author Share Posted September 5, 2016 I agree with Robdraw the blocks must match, but a quick and dirty use Filter pick the block remove the co-ord's etc so it picks all of them.MOVE P 0,0 newx,newy The issue I am having is that these new blocks have attributes that did not exist in the old blocks. The blocks seem to all have the same insertion points now that I updated them, but still any instance where the original block has been rotated - when I go to replace them the attributes move all over the place? Is there a reason for this, is it because the old blocks have no attributes? Quote Link to comment Share on other sites More sharing options...
RobDraw Posted September 6, 2016 Share Posted September 6, 2016 The issue I am having is that these new blocks have attributes that did not exist in the old blocks. The blocks seem to all have the same insertion points now that I updated them, but still any instance where the original block has been rotated - when I go to replace them the attributes move all over the place? Is there a reason for this, is it because the old blocks have no attributes? Can you show us what you mean by "move all over the place"? Even better, post an example file with both the old and the new blocks in it. Quote Link to comment Share on other sites More sharing options...
