Results 1 to 4 of 4
    Senior Member sivapathasunderam's Avatar
    sivapathasunderam's Computer Details
    Windows 7
    4 GB
    NVIDIA GeForce GT 240
    195 GB
    736 GB
    Samsung LED Monitor
    Transport
    sivapathasunderam's Discipline Details
    Draughtsman
    Transport
    AutoCAD 2013
    Apr 2015
    Muscat
    101
    Unhappy Upgrade of Plan Production tools
    Dear Gentlemen;
    I am using AutoCAD civil3d 2014
    I prefer to have one more option as shown in an image below
    I have more works on Plan & again Plan works as below image
    thanks
    Siva
    Windows 7
    4 GB
    195 GB
    736 GB
    Samsung LED Monitor
    Transport
    Draughtsman
    Transport
    AutoCAD 2013
    Apr 2015
    Muscat
    101
    Hello anyone;
    There are many drawings we need Plan views without Profile
    In one sheet 2 Plans
    I try using Plan only option & cut the sheet 2 Plan viewport, bring to sheet 1 bottom area, the PC get struck (not responding)
    If this works for me, I can do this for same length like; 5, 10 or 20Km, but for more than these Kms not possible
    Example:
    1.) Street Lighting Layouts,
    2.) Topographic Survey Layouts,
    3.) Existing Utility Services & Proposed Relocation Layouts,
    4.) Land Acquisition Plans
    I look forward to hear from you
    thanks
    Siva
    Last edited by sivapathasunderam; 10th Sep 2016 at 03:18 pm. Reason: added examples
    Windows 7
    4 GB
    195 GB
    736 GB
    Samsung LED Monitor
    Transport
    Draughtsman
    Transport
    AutoCAD 2013
    Apr 2015
    Muscat
    101
    No one reply!!!
    [IMG][/IMG]
    thanks Autodesk
    Quantum Mechanic
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,402
    The only suggestion I can think of is to make all the sheets then use something like this copy layout to copy every second layout tab to the prior one then delete the blanks.
    You would need a custom sheet set maker for two sheets as the viewport needs to be rotated as you walk along an alignment.
    Change the paste insertion point
    Code:
    ; copys a papersapce layout to another layout
    ; By Alan H Oct 2014
    (defun C:cplay ( / alllayouts lay num x ans oldsnap)
    (setq oldsnap (getvar "osmode"))
    (setvar "osmode" 0)
    (setq oldtab (getvar "ctab"))
    (command "zoom" "E")
    (command "copybase" '(0 0 0) "W" '(0 48) '(801 554) "")
    (setq num (getint "\nEnter tab number"))
    (setq alllayouts (vla-get-Layouts (vla-get-activedocument (vlax-get-acad-object))))
    (SETQ LAYNUM 0)
    (vlax-for lay alllayouts
    (if (= num (vla-get-taborder lay))
      (setvar "ctab" (vla-get-name lay))
    ) ; if
    ) ; for
    (command "move" "W" '(-900 36) '(820 570) "" '(0 0) '(-840 0))
    (command "._pasteclip" '(0 0 0))
    (setvar "osmode" oldsnap)
    (command "Regen")
    (setq ans (getstring "\nTo go back to original layout press <Cr> any key exit"))
    (if (= ans "")(setvar "ctab" oldtab))
    ) ; defun
  1. Plan Production in Civil 3D
    By yasin2ray in forum AutoCAD Beginners' Area
    Last Post: 23rd Feb 2011, 02:23 am
  2. CIVIL 3D PLAN PRODUCTION - for Large Subdivisions
    By Old Timer in forum Civil 3D & LDD
    Last Post: 29th Aug 2010, 07:09 am
  3. Production
    By fjaniswilshire-homes in forum AutoLISP, Visual LISP & DCL
    Last Post: 27th Jul 2010, 04:09 am
  4. Production
    By fjaniswilshire-homes in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 24th Jul 2010, 11:51 am
  5. Will an AutoCAD 2004 upgrade CD upgrade Release 14?
    By kjsarchtech in forum AutoCAD General
    Last Post: 16th Sep 2009, 03:01 pm
