Results 1 to 6 of 6
Thread: making solids
    Senior Member
    not specified
    Jan 2006
    211
    Default making solids
    The figures below are a screen shot of a shape I made in AutoCAD 2006. The first one show the front and the second one shows the back. As you can see from the back, it's hollow inside, and so the shape is not a solid but a collection of round surfaces. Now I need to cut it along the lines marked in red. I can't use the slice command since that only works on solids. If I covered the opening in the back with one more ring shaped solid, would there be a way to convert it into a solid?
    Senior Member Ako's Avatar
    AutoCAD 2007
    Mar 2006
    Warrington UK
    310
    How did you create it ? I created a similar component by using successive cylinders and subtracting them as required. Slice seems to work on this piece.
    Dave
    Senior Member
    not specified
    Jan 2006
    211
    That might be what I'll have to do. I just didn't want to re-create the thing all over again.
    Administrator CADTutor's Avatar
    CADTutor's Computer Details
    Windows 7 Home Premium 64bit
    Asus P7P55D-E PRO
    Intel Core i7-860
    4GB PC3-12800 C8 Corsair Dominator
    NVIDIA Quadro FX 1800 768 MB
    Intel X25-M SSD 160GB
    Samsung Spinpoint 320GB
    BenQ FP241W 24" Wide
    Education
    CADTutor's Discipline Details
    Senior Lecturer (Digital Design), Landscape Architect & Web Designer
    Education
    AutoCAD 2014
    Aug 2002
    Hampshire, UK
    3,606
    Or, simply draw the section and then use REVOLVE to creare the solid.
    Tip: Please do not PM or email me with CAD questions - use the forums, you'll get an answer sooner.
    AutoCAD Tutorials | How to add images to your posts | How to register successfully | Forum FAQ
  5. #5
    AutoCAD 2007
    Mar 2006
    Warrington UK
    310
    Too easy!! Does it show that I don't use 3D very much?
    Dave
  6. #6
    Senior Member
    not specified
    Jan 2006
    211
    Quote Originally Posted by CADTutor View Post
    Thanks a bunch! If only I had known.
  1. making transparent
    By levent in forum AutoCAD 3D Modelling & Rendering
    Last Post: 5th Sep 2006, 08:55 am
  2. making an arc a polyline
    By Jeffnm in forum AutoCAD Beginners' Area
    Last Post: 31st Jul 2006, 07:42 pm
  3. importing solids into 3dsmax5 - solids coming out see thru?
    By ironman2 in forum AutoCAD 3D Modelling & Rendering
    Last Post: 19th Sep 2005, 05:21 am
  4. Making a point
    By Watto in forum AutoCAD General
    Last Post: 6th May 2005, 11:24 am
  5. Making a new .pgp
    By myk26 in forum AutoCAD Drawing Management & Output
    Last Post: 25th Jun 2004, 05:51 pm
