Page 1 of 2 1 2 LastLast
Results 1 to 10 of 12
    Forum Newbie
    AutoCAD LT 2017
    Sep 2016
    2
    Default New to Xrefs-dwg was emailed, but no Xref
    I was emailed a number of dwgs that have Xrefs, but from what I understand, I need access to the original/referenced dwgs? When I open my "External References" pallette, it shows "unreferenced", and "not found" references. The paths are to the customer's server? I think I'm missing the original file, but I'm new to this Xref, so I'm not confident that I'm doing everything right.
    Forum Deity rkent's Avatar
    rkent's Computer Details
    WIN7 PRO 64bit
    Dell OptiPlex 7020
    i7 4790 3.6GHz
    16GB, 1600MHz, DDR3 non-ECC 2x8GB
    AMD Radeon 2GB
    Samsung 480Gb SSD
    Dell 24" FS (2x)
    Mechanical
    rkent's Discipline Details
    Mechanical
    Mechanical 2017
    Nov 2007
    4,595
    The sender has to send all the drawing files to you. Look up etransmit and then ask them to do the same.
    Or they need to bind the xref drawings first before sending.
    Sometimes there's a man... I won't say a hero, 'cause, what's a hero? But sometimes, there's a man. And I'm talkin' about the Dude here. Sometimes, there's a man, well, he's the man for his time and place. He fits right in there. And that's the Dude, in Los Angeles. - The Stranger, The Big Lebowski
    Forum Deity Dana W's Avatar
    Dana W's Computer Details
    Windows 8 64 bit
    Dell XPS ONE 2710
    Dunno
    Intel I-5 3330S @ 2.7 Ghz
    6 Gb
    On board barely adequate
    1 Terrabyte
    1 Terrabyte external
    All in one 27" touch & pen
    Construction
    Dana W's Discipline Details
    Architectural Millwork Designer/Draftsman
    Construction
    Custom commercial millwork.
    AutoCAD LT 2019
    Feb 2010
    Oviedo, Florida
    4,769
    Quote Originally Posted by andrews7412 View Post
    The "unreferenced" is not something to worry about. It means a file was inserted probably only for working information as an xref but then erased. In the xref manager, select the unreferenced item, right click and click Detach.
    The S197 gen Ford Mustang, and the F-4 Phantom both prove the same theory. "With enough power applied, a school bus will fly."
    Luminous Being RobDraw's Avatar
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,173
    Yeah, unreferenced can be ignored. If you are unsure if you got all the files, make sure to place all of the incoming files in the same folder. AutoCAD will find them even if the pathing is incorrect.
    Drafting is a breeze.
  5. #5
    Forum Newbie
    AutoCAD LT 2017
    Sep 2016
    2
    Default Thanks guys
    I'm just getting back into ACAD and these Xref drawings are missing all kinds of info, like walls. So if I put all the dwgs related to this project into a single folder, then open them, and the walls/info is still missing, that would mean I didn't get all the necessary files from the customer right? Because I'm doubting myself, I just want to know how to verify I didn't get the files, before I tell someone that I didn't get them...
  6. #6
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,173
    Compare the list of XREFs that are not found to the list of files to verify.
  7. #7
    Super Member halam's Avatar
    AutoCAD 2017
    Jul 2015
    694
    Any change these DWGs we're exports coming from third party software?
    Modelling is done with two hands, 2d & 3d. Let it work together..
    https://twitter.com/halammerts
  8. #8
    Windows 8 64 bit
    Dell XPS ONE 2710
    Dunno
    6 Gb
    1 Terrabyte
    Construction
    Construction
    AutoCAD LT 2019
    Feb 2010
    Oviedo, Florida
    4,769
    You may or may not have them, and some of them may be nested within others xref'ed to your main dwg.
    You probably should open each xref to see if they have nested (sub) xrefs. To make sure of which ones you do have,you simply have to refresh the paths in any of the dwg files with Not Found xref issues.
    keeping all of the drawings in the same folder with the main dwg will simplify re-pathing. Open the xref manager in any dwg that has xrefs, shift select all xrefs, right click, select Path, select Make Relative. That will re-path all the xref links to your local folder. With the paths set to relative, AutoCad will look first in the same folder the main drawing is in. Once the paths are all relative, then you know the ones marked Not Found are the missing files. If the path is not relative, as in absolute then AutoCad will only look down the previously saved path which right now may still be pointing to the client's computer, and the files will still not be found even though you have them.
  9. #9
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,173
    AutoCAD does find them, if they are in the same folder, regardless of the pathing. That's why I suggested it earlier.
  10. #10
    Windows 8 64 bit
    Dell XPS ONE 2710
    Dunno
    6 Gb
    1 Terrabyte
    Construction
    Construction
    AutoCAD LT 2019
    Feb 2010
    Oviedo, Florida
    4,769
    Quote Originally Posted by RobDraw View Post
    If the pathing is absolute? I never set pathing absolute so I don't know.
  1. Plotting Emailed Drawing at A3
    By j4cksincl4ir in forum AutoCAD Drawing Management & Output
    Last Post: 13th Nov 2013, 12:46 pm
  2. Lisp: Put all XREFs on layer "G-XREF"
    By mrharris78 in forum AutoLISP, Visual LISP & DCL
    Last Post: 13th Feb 2013, 10:47 am
  3. Annotative text in XREF? Xref units mm, parent drawing m
    By spittle in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 3rd Aug 2009, 09:06 am
  4. gray scale xrefs vs. xrefs with full range of pen colours
    By corinne in forum AutoCAD Beginners' Area
    Last Post: 26th Aug 2008, 09:56 am
Tags for this Thread
